Wouldnt it make no difference how many BOVs are fitted in relation to holding boost?
1,2, 5 or 10 of them fitted I thought would not give any increase in boost holding ability.
e.g If you had one of the plastic Bosch BOV and it leaked at 10psi I thought fitting another one would result in both of them leaking at 10psi?
I always thought the reason for having more than one BOV was for when running higher boost levels (36psi) it gave more total cfm release as only one fitted would struggle to vent all the excess pressure/air?
They would just share the pressure.
Each would pass half the air a single unit would vent.
Get two coke cans, shake them.
Poke one hole in can A.
Poke two holes in can B.
The pressure of the liquid ejected from Can B, will be half the pressure ejected from Can A.
Twice the total CFM, half the pressure.
No Each would pass half the air of one.
As the BOV is set at a X pressure they would release at the same time
under the same pressure but would escape twice as fast
Cant use the can theory here. Its Not the same as BOV as the BOV is pressure set.
Twice the CFM but same pressure as a single BOV.
:D
__________________
To combat boost holding problems, dont companies have varying strength springs that you can install? My cousins 1JZ's blow off valve had a different spring in it, so it would blowoff at lower pressures because he was running low boost...
The spring constant determines how hard a spring is, get a stiff spring fabricated to suit?
    • Hey everyone!!  I've noticed that whenever I do my oil changes, after putting 4L in, the oil level sits at the top mark in the dipstick. This is after letting the old oil drain for a very long time too! I've checked the oil level daily for the past few mornings. It happens every time and it's confusing because all the threads say that it should take about 4.7L (With some just adding the full 5L) My next thought is to figure out if the dipstick I have is correct so could someone please tell me the length of the RB25DET engine oil dipstick?  I've checked images of some of the genuine dipsticks, but none of them have the length in it. https://justjap.com/products/genuine-nissan-engine-oil-level-dipstick-fits-nissan-r34-skyline-c34-stagea-c35-laurel-y34-cedric-gloria-rb25de-t-neo?currency=AUD&srsltid=AfmBOortQXofgmiHVRKuIaiKuygL4k0Ewp68c3isGZk0vvKOJ7Yqf3iB However.... the engraving on the genuine ones say 05002 while mine says AA000. This makes me believe that maybe I have a wrong dipstick? I just want to confirm before I buy a new one. The car is a fresh import from Japan so I don't have details of the previous owner to ask him. Thanks in advance 🙏🏾
    • Sport. I didn’t rebleed it cause I just removed the slave and left connected.    I will change line and slave and see how it goes.
    • Oh and how is the rattle when foot is on the clutch ?
    • Did you get the sport or track ? From what the documentation says the uniclutch has a small amount of movement to disengage.  So your story of tricky pedal setup seems common.    Hopefully you got it bled up too, as the bite point moving around is usually either plates wearing in or air in the line.
    • There's always "MIG it up and grind it back".
