Hi all,
Im selling my aus spec 31, :'( , i love the thing to death, but i need something more practacle for my new job (newer, etc to take clients in).
i bought it a few months ago, its been perfect ever since, except the blown head gasket, i dont have the time, nor patience to fix it, plus i was looking at selling it anyways, gives someone the chance to grab a bargain.
I have since added a VG30 turbo, which i have been told has been hi flowed (no written proof), i also have the spare RB20 Turbs in excellent condition.
It is a perfect daily driver, goes very very hard, is comfy, great on fuel, and very drivable, cops dont evn give a second look!,
only probs now are : bald rears, can arange some cheap second handies if needed.
car still drives fine!, idles rough due to gasket, probably dont wanto drive it long though as it is, as coolant is in oil.
see original owners advert for it here:
http://forum.r31skylineclub.com/index.php?...g96305#msg96305
1989 Series 3 GXE
silo dash
KYB adjustable shocks / Kmac springs
16x7 impul rs alloys w/ 225/50 tyres
Autometer boost and Oil pressure gauges
3" exhaust + hi-flow 3" Cat
pioneer DEH3450 CD deck
US Audio 800 watt amp
VL turbo fuel pump
new brakes all round
R32 rb20det
big front mount cooler
Fully rebuilt 5 speed and HD clutch
4.5k as is with spare stock RB20 turbo - pretty dam firm on price as the next car is costing me 20k, if i dont sell it for around that price i will just keep/store it till im in a position to fix it.
cheers
Ben
0403399335
[email protected]
https://www.sau.com.au/forums/topic/56683-r31-w-rb20det-fmic-sleeper/
  • 3 weeks later...
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
