MAKE AN OFFER !!!
Cleaning out the garage and want to get rid of some things
Series 1 m-spec rear bar n pods - $90 (silver) SOLD
Series 1 Grille (silver) - $70
Series 1 Spoiler (silver) - $90 All LED's in brake light are working
Series 2 spoiler (silver) - $130 with brake light
Stock Cat-back exhaust without muffler - $30
Stock front and dump pipes - $40 for both
Stock Air box and filter - SOLD
M spec rear pods (red) - SOLD
Stock R33 springs - SOLD
Parts located in Sydney, pickup preferred but will send interstate at buyers expense
PM me for more details
https://www.sau.com.au/forums/topic/56707-r33-bargain-parts-galore/
