Your a bit late R33SUM... There "was" a private section for organising cruises, but it's been abandoned for now... We got up to plenty of mischief without the cops knowing during that time...
As Nexus says, if the cops want to come along and cause problems at a CHARITY CRUISE, then our already depleted opinion of them will surely suffer...
No... no one did... it was always for the kids!
*remember they are still watching!*
yep shes right has those sick orange lights that let u know when ur slippin..(as if u already dont know) eh dont think ne thing bou tthe stereo is different just maybe a different year...although i doubt many skylines have their stock stereo in them...hey nismo girl how often u change ur oil for ur diff and wat type u use??
Uhm.. next question? :cheers:
I just get a major service done each year flushing out and changing any type of liquid in the car.
And as to the brand of the oil, you'll have to ring Gavin Wood - Autotech to find that out. I have no idea. I just pay for it :?
As for the carpark and stuff being blocked off, this is the third massive skyline cruise we've had and not one has created any cop attention (except the last, but locals got a bit scared of 50+ cars going into a carpark at 11pm at night). They just stopped and asked what we were doing and general questions and they were off.
But as the guys said, it would be pretty pathetic and disheartening to block off a carpark for a group of entuisiasts who are doing the right thing and raising money for sick kids.
just wanted to say  a hola to all you skyline guys and girls in Qld, just recently moved from adelaide to study up here on the gold coast...nice weather....nice girls...nice cars heheh
give us a yell if yah see me ull know its me cos of the SA pl8ts hehe :Oops: .
l8r
You have my deepest sympathies, didn't know they had uni's or that they even studied there.....
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
