Hey guys, I've done a few mods to my R33 now I've got the taste of power, I want more
I want about 250kw at the wheels, without all the lag
What size turbo have people found will do that job
Sex should be like a skyline- Quick obscene and loud enogh for the whole street to hear when you come
https://www.sau.com.au/forums/topic/56716-whats-a-good-street-turbo/
So u made 250rwkw @ 17psi with standard ECU, standard injectors, standard afm?
safc2 etc?
oh and my turbo choice would be HKS GT-RS
i didnt say that. The ECU is stock meaning in does have a chip in it but it is not an aftermarket one such as a wolf or a Powerfc. And yes i do have 550cc injectors
the xr6 turbo is pretty big its like a gt30 or 35 or somethin, highly doubtful it bolts straight on to a stock manifold...
sydneykid: so out of the GCG high flow and a HKS 2835s, would u still pick the high flow? im deciding which one to go for, but a few $$ extra (from nengun 2835 is 2500 delivered) would it be worth it?
ben...
ben...
I decided against the HKS as I wasn't going to pay more money for something I could achieve with a high flow of the standard turbo. Don't get me wrong the HKS GT2835 would be great and I bet would be maybe 5-10% (better then high flowing your standard R33 Turbo but for the money why bother, you could save yourself plenty by going the high flow way and at least you can put that into a better dump or manifold :)
just cos you save money on something does mean you can't spend it on something else the car may need :D
I am currently highflowing my stock turbo to a GT30 standard.. not sure what style like GT3030 or GT3040 but enough to give about 600 odd horsies :)
GCG Ball Bearing high flow, 265 rwkw and more power EVERYWHERE than standard:cheers:
Hi sk.
What about the power delivery of the hi-flow?Do you have any dyno graphs?
If no.How does it compare to a 2530/35 garett or hks.You had tomei poncams as well for that figure to right.
What are the comp housings/exh housing specs of the stock unit high hi flowed.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
    • Got just the wing painted and fitted up to the existing boot. Big visual change and about time after having a GTR wing sitting in the shed since 2018 Headed up to Mallala with a quick obligatory stop in at Boliver OTR Oil control mods seems to have worked. I checked the catch can after session 1 and there was a dribble of water/e85 with barely any oil in it. After session 2 and 3 there was almost nothing and I stopped checking after that. so either great success or catastrophic failure/block of the external breather The GTR wing made a noticeable difference in the 160-185km/h sweepers. It was a very hot day for the cars at over 33C but the previously done cooling upgrade/ducting/water sprayers meant I never saw over 60C intake, 105C water and 100C oil and temps would drop back down very quickly once I shut it down. AD09's are a decent tyre but certainly and expectedly a step down when compared the the CR-S/AR-1 I have had on the car for years of track days. The handling characteristics of my car which I often describe using the Tony Hawks Pro Skater balance mechanic where either side of the center is understeer/oversteer was much more pronounced with no "green/safe" zone in the middle. However, imo it steers well/easily during oversteer largely thanks to the custom ACOSTAL front end. Enjoy a loose lap POV with my mate giggling away as a passenger.   Group photo for Peer Pressure Racing made it back home and gave it a wash Overall a great success compared to my previous two track days where i cooked the Starlets motor and blew up the new diff in the R32
    • Nice. I'm looking forward to the updates!
    • Ayooo, been a while mates. I have a s2 r33 gtst and air stopped coming out of all the top vents.   My car has always made an actuator gear noise when turning the car on but that's a different issue I think? Did searches and am at process of thinking it's an actuator or some type of motor? I see a few different actuators and don't know which one. Would be nice to know if it was the one that's under the steering wheel so the dash doesn't need to come out.
    • Hi, just checking. Did you get this stuff made by Vspec Performance and at what price roughly? Looking into (sometime later) also getting such a intake kit, and Trust as well as HKS don't make a full set like this anymore.
