Hey guys, I've done a few mods to my R33 now I've got the taste of power, I want more
I want about 250kw at the wheels, without all the lag
What size turbo have people found will do that job
Sex should be like a skyline- Quick obscene and loud enogh for the whole street to hear when you come
https://www.sau.com.au/forums/topic/56716-whats-a-good-street-turbo/
So u made 250rwkw @ 17psi with standard ECU, standard injectors, standard afm?
safc2 etc?
oh and my turbo choice would be HKS GT-RS
i didnt say that. The ECU is stock meaning in does have a chip in it but it is not an aftermarket one such as a wolf or a Powerfc. And yes i do have 550cc injectors
the xr6 turbo is pretty big its like a gt30 or 35 or somethin, highly doubtful it bolts straight on to a stock manifold...
sydneykid: so out of the GCG high flow and a HKS 2835s, would u still pick the high flow? im deciding which one to go for, but a few $$ extra (from nengun 2835 is 2500 delivered) would it be worth it?
ben...
ben...
I decided against the HKS as I wasn't going to pay more money for something I could achieve with a high flow of the standard turbo. Don't get me wrong the HKS GT2835 would be great and I bet would be maybe 5-10% (better then high flowing your standard R33 Turbo but for the money why bother, you could save yourself plenty by going the high flow way and at least you can put that into a better dump or manifold :)
just cos you save money on something does mean you can't spend it on something else the car may need :D
I am currently highflowing my stock turbo to a GT30 standard.. not sure what style like GT3030 or GT3040 but enough to give about 600 odd horsies :)
GCG Ball Bearing high flow, 265 rwkw and more power EVERYWHERE than standard:cheers:
Hi sk.
What about the power delivery of the hi-flow?Do you have any dyno graphs?
If no.How does it compare to a 2530/35 garett or hks.You had tomei poncams as well for that figure to right.
What are the comp housings/exh housing specs of the stock unit high hi flowed.
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
    • Evening all. Got this odd issue with my R34 GTT. If I let the car idle for around 15 seconds or more (even when cold) and I jab the throttle a bit, a decently sized plume of blue/grey smoke comes out the exhaust. Doesn't smoke when idling alone, just when giving it some gas after idling. No smoke on cold start or from what I know, normal driving. Not 100% sure about smoke on decel but I don't think there's any. Any pointers on what I should start doing to troubleshoot it? Or if anyone has experienced the same I'd love to get some insight. Cheers.
