1. A set of USED 6 Trust piston 87.5mm bore with 21mm pin, with trust piston ring set. = $1100
2. A set of near new 6 Trust Conrod with 21mm pin (for stock crank), it is in PERFACT Condition = $1700.
Below are Due to some sick people whom say they wanted it and leave me some deposit but end didnt even reply any single of my email for few weeks so therefore it is up for sale again.
3. Near new Split Fire Coil for RB engine = $600
Contact [email protected] or 0418 388 125 (Melbourne CBD)
Thanks
Calvin
