Now i know that this topic has been done to death but i figure i might as well ask.
I looked down at the odo this mornin and low and behold its time for an oil change AGAIN.:eek: feels like i just did it last week.
So my question is basically this: do u think its completely nessacary to change the oil/filter every 5000ks or can u run it little longer depending on how u been treating it?
U know i value all opinions no mater how moronic they may seem:lol:
https://www.sau.com.au/forums/topic/5673-oil-change-intervals-opinions/
Hehe well that goes with out saying doesnt it. Last time i asked an aunty this question she said "huh what doesnt the oil just top itself up?"
I come from a family of car abusers.
My bro got home this morn when i was just pulling out to go to work and he gets out of the car walks round the front and opens his bonnett and puts his radiator cap back on that he just found on the floor as he pulled up. Now call me ismail but i think he was driving all last nite with no radiator cap on and he fills it when its overheating with cold water and wonders y it pisses water all the time sheesh :eek: this is the guy that has cracked 2 head gaskets 1 in a merc and another in an eb falcon from the same thing , drving with no oil or water in the car . *sigh*
Im pretty fanatical about oil. I do mine every 2000kms of hard driving, or around 3000 of not so hard driving. But then i dont drive it that much, so can afford it easier :P
I do it for peace of mind more than anything. Just like to know that the engine always has clean fresh oil.. MMmmm.
:burnout: :burnout: :burnout: :burnout:
(Motul 6100 synthetic ~50-60 bucks for 5 litres i think. Have been using Purulator filters, but changing to the Hard Driver filters)
Own ure own company do ya;)
Every 2000ks, thats nutz!!, especially considering how much u pay for oil.
I drive mine to work and dont really have the second car luxury so alot of the ks are done in traffic on just cruzin.
So u change the filter with every oil change
Jebus Boostzor, you couldn't have changed oil more than 8wks ago, 5000k already. Too many aimless cruises, eh? :) Oh yeah, tell your brother he's an assclown for driving around without a radiator cap.
SLY33, could you tell us more about Purulator and Hard Driver filters, including price and any reasons why they may be better than genuine Nissan filters?
I can tell with my 32 that when it gets to around the 5000 km mark after a service it is a little harder to start when cold or warm and doesnt idle quite as nicely..
I change oil/oil filter/check fluids/clean air filter every 5,000...
Have to do my diff oil when i service it on the weekend as well...:)
I've done ~13,000 klms in a bit over 2.5yrs (the time I've owned the car) I've done 6 or so oil changes in this time!
I change my oil based on how I've used the car since the last change, or on time (months) If I changed it based on klms I wouldn't do many oil changes!
Excessive? Maybe? But I'm happy knowing fresh Motul 300V is doing its best :)
I'd say 5k/6months is a good guide in most cases. Turbo engines are very hard on oil.
Change the gearbox oil after every track day?! Jeebus!!!!!
Transmission oil is different to engine oil. Most of the contamination in engine oil comes from the partial burning of it, plus it gets mixed in with fuel etc, all of which end up breaking down the rest of it.
A gearbox is a sealed unit though, with no burning going on. It only wears out as the gears squish all the oil molecules together and they eventually get separated and they don't lubricate properly anymore. You do tend to get some metal particles in the box, but most of these settle down the bottom and aren't too much of a concern.
My gearbox had never had an oil change when I got the car at around 85000, so when I changed it there was a LOT of metal in it. And yet the box was good both before and after without too much of a concern. You're only getting a few shavings after a track run, if you're running a good quality transmission oil (eg Redline) then I don't see why you'd change it after every track day unless you were racing professionally or something and someone else was paying for your oil.
As for engine oil, I change it every 5000 just for simplicity's sake, but I pay attention to the colour. It should end up a sort of dark brown/gold colour when I change it, I never let it go completely black (which it usually does by 10000). As long as it still has some of the gold colour left in it, it's doing well over 90% of the work it was doing when it was fresh. With my current driving habits the oil so far is still fine and it's almost done 5000 since I got it.
A good quality filter is essential, never skimp on that. A good quality filter should last for 10000, but what you're more concerned about is the size of the particles it lets through even when it's brand new.
    • I just changed the timing belt on my RB25DET NEO and wanted to get some opinions. I’ve been super cautious, did a lot of research, and took my time. I’ve driven the car, and it runs fine. After warming it up, I revved it to 8000 RPM a few times—no issues, everything held up.   After the drive, I heard a noise that I think is either the clutch or possibly a tight accessory belt. It’s not constant, just comes and goes.   I took the timing cover off to double-check everything:   Belt is on properly, Tensioner is tight, Did the 90-degree twist test—belt isn’t too tight or too loose.     What still worries me is that I noticed the belt seems to sit a little toward the front edge of the gears, especially on the idler pulley. It even looks like it’s slightly coming off the edge there. Is that normal?   My old belt (5 years old, ~3,000 miles) also showed a bit of wear on that same edge, so maybe it’s just how it sits? I’m probably overthinking this, but since it’s my first time doing this on a NEO and the engine is forged, I really don’t want to mess anything up.   Also, I’m thinking of swapping to a clear front timing cover with the glass window. Would you recommend NITO or HPI? HPI looks reputable and their covers have 2.5mm thickness, but not sure if there’s a real difference between the two.   Any advice or reassurance would be much appreciated!
    • 40 grit sounds about right, to start. You make some decent cuts/damage in the coating with that, then rapdily scale up to maybe 80 and 120 for the bulk of the actual removal, then fine it off to 180 or 240 perhaps. No need to go any finer than that, and maybe no need to go even as fine as that. Wrap it on a big block and have at it. At least on the hub face.
    • Do the GKTech rear lower control arm mount relocation, and either alloy subframe inserts or very stiff subframe bushes. Traction is going to be at a premium!
    • Hello,   My name if Frederick, i'm 30 years old and I live in Belgium, Europe! I used to have a Nissan 370z daily but since I got a company car I turned that into my seattime driftcar. About 3 years ago I also wanted something older with more feel, so I got an R32 GTST with an rb26 engine. I am now getting the rb built to have around 800hp and it's close to being finished. I'm very excited for how it will drive and how driveable it will be! Regards, Fred!
    • Appreciate the insight! Talked to some local folks and they basically told me "it's not that deep." As long as the threading on the inside matches what's at the steering rack, everything else can be constructed-to-fit. There are full aftermarket kits I can use - probably better for my car overall since it's lowered.  Example: GKTech M14 Super Adjustable Inner Tie Rod Set - Nissan Skyline R32 R33 R33, 240SX, 300ZX, 350Z / Infiniti G35 M14I-TROD-2 gktM145-TROD gktM14I-TROD - Concept Z Performance (These can be packaged with their "high misalignment" tie rod ends).
