Hey guys
my clutch on my r32 gts-t is on it's way out. Tonight started to slip in first at the top end.
So what I probably want to look at is getting a new clutch but I want something a bit more bitey than stock and not as bitey as a brass button.
So really i just want something better than the stock clutch. I dont want a clutch that would make my car imposible to drive.
So if you's guys have any thoughts what would suit me best it would be greatly apreciated.
Thanx Guys.
https://www.sau.com.au/forums/topic/56740-new-clutch-qs/
My mate got an organic centre which is pretty nice but not ridiculous - I stalled it first time I got in it but 2minutes later I was used to it and it drives great... When I get my next clutch I'll be getting the same.
He has a stock r32 and (over)paid $800 installed.
https://www.sau.com.au/forums/topic/56740-new-clutch-qs/#findComment-1098207
My mechanic has quoted me $800 for an organic twin plate clutch fitted with the flywheel machined. I have been trying to decide on a heavy duty or twin plate and i think the twin will be better in the long run. He quoted $550 for a heavy duty fitted.
If you want his details send me a pm
Steve
https://www.sau.com.au/forums/topic/56740-new-clutch-qs/#findComment-1098680
Hmm that's realy tempting there R33 steve.
I called the mechanic i usually go 2, I'm going 2 get him 2 have a look @ it 2morrow,
For a quote.
Is the twin plate going 2 be hard to drive with or still has enough give to drive round through traffic easily.
https://www.sau.com.au/forums/topic/56740-new-clutch-qs/#findComment-1099145
how much power is it making?
I emailed Exedy asking what they could offer me for an rb20det, had to hold at least 200rwkw etc. They suggested their sports organic kit, part number NSK-7056SO.
The max torque rating on this clutch at
7000 rpm is 393 ft/lb at the flywheel, max 524 hp or 391 kw also at the
flywheel.
Unless your trying to hold a whole lot of power, this kit might be worth a look.
goodluck
Tim
https://www.sau.com.au/forums/topic/56740-new-clutch-qs/#findComment-1099708
Ok.
Thanx Steve for the advice. I probably stick to the heavy duty clutch. Might get a daiken heavy duty clutch I think.
I might change it after the new year. As it seemed to drive alot better today.
Would not slip on me. I even droped the clutch and it slipped just a little. So in the new year new clutch.
Also gives me abit of time to get what i realy want. Which at the moment is becoming more clear.
Thanx guys for the input its been of great help.
https://www.sau.com.au/forums/topic/56740-new-clutch-qs/#findComment-1100950
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
