I've done about 5,000kms since I bought my Skyline, so its about time to do an oil and filter change (previous owner had the car serviced just before I bought it). So I was just wondering what oil and filter people would recommend for the Skyline. I regularly used Mobil 1 synthetic oil and a basic Ryco filter for my old car and thought it did the job well, but I've heard from quite a few people that Motul is the go for Skyline's. Can anyone confirm?
Also, what viscosity oil is best to use?
Thanks for the help.
https://www.sau.com.au/forums/topic/56851-oilfilter-choice/
Not trying to sound rude but there are alot of threads about oil choice and filter choice here already. Try searching!
If you're lazy then I use motul 8100 5/40 with a JIC (j-brand) oil filter. Ryco apperantly are shite - I must admit so far when I used a Ryco for about 200km my fresh motul came out black as the ace of spades. I've been using my JIC one for about 400km and the oil is still golden brown (texture like sun..).
Might be coincidence may not be - the JIC one was more expensive.
PS: I have a sr20 but I'd use the same thing on a RB.
https://www.sau.com.au/forums/topic/56851-oilfilter-choice/#findComment-1099761
Use a Nissan filter. You cant go wrong with them.. I wouldnt trust Ryco. In my experience they are shit.
Motul are a good oil company. Their 8100 series would be ideal for your car and you can easily do 10,000k intervals on those oils.
https://www.sau.com.au/forums/topic/56851-oilfilter-choice/#findComment-1102338
I always used a ryco filter.
Z145A. No problems yet.
You'll find there is much debate wether which oil is better than the other. I dont think there much all that differnce between them (with in reason mobile, motul etc.). If u plane to change it every 5000k's it probably not worth spending big bucks on top line top brand oils.
But If your loaded with cash and money no object than its a differnt story.
I using a Penrite semisynthetic oil Hpr5
5w 40
at the moment. And i dont have any complaints or problems.
https://www.sau.com.au/forums/topic/56851-oilfilter-choice/#findComment-1102477
I use ryco an havent had any dramas. I went to a ryco info night for work, and comparing to other popular filters on the market there either as good or better. I was even under the opinion they were cheap an nasty until I saw all of there research and comparisons...
Noticed a ryco filter on the orange S15 (when i saw it @melb autosalon)with a AWSOME RB26 under the hood thats on the cover of autosalon magazine.....so they cant be that bad
:D
Berin
https://www.sau.com.au/forums/topic/56851-oilfilter-choice/#findComment-1111867
I tend to use a 10w 40w oil.......(RB20det)......i tend to also stick with sem synthetic simply due to the lower cost........NOTE: I service my "normal" car (R32) every 5000klms with general driving, very little thrashing. But service the "drift " car every 2000klms.
I really don't see the need to sepnd double the amount when the oil is coming out looking nearly as good as when it went in.
https://www.sau.com.au/forums/topic/56851-oilfilter-choice/#findComment-1111913
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I could do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free. It's only about 50L per year, but that's ~$100. A few extra pizzas is always welcome. Note that I have a record of every tank of fuel that has ever gone through my car except for a handful put in by someone else, like my mechanic. I can show you the difference between stock RB20 and tuned RB20, stock RB5Neo and tuned, winter and summer fuel blends, winter and summer fuel blends when the ambient temperature is not appropriate for the blend, working O2 sensor, blown O2 sensor, boosting f**k out of it and frightened to boost it because it is pinging, and so on. OK, I probably can't do all that now with 100% clarity - but at the time when any of those things were in event, you could see it in the records. There's 25+ years of simple tank after tank records, so you have to look for landmarks to work out approximately how old any single record is. What's really important is the meta data and that lives in my head.
    • If you're claiming the issues are not skyline specific, then either the USA is living in the 90s / early 2000s, OR you have the issue of "survivor bias". Which is you're mainly hearing and listening to those with terrible experiences, and haven't found the guys who have cars with good decent builds and no problems. It happens in AU too, that plenty of people keep having issues, and they keep going to the workshops that are known to be shit "because I read on the internet". Even worse, are those who keep posting on the internet as though they know for a fact what something is, when they've never touched/looked at said item in their life, and again are making assumptions, based on something they read, or because it's a certain way in other cars. It's even funnier when those same people debate the facts with the people who've lived and breathed this stuff for over 15 years. Example, I've had someone tell me you can't do something with a Skyline, because they read it on the internet, except I can tell they're wrong, as I did that exact thing back in 2008 with my Skyline.
    • The funniest part I saw, was someone would bitch and moan on FB about something, Andy would be the one to respond, asking for more info, if he could contact them, what the engine setup is, what their config file was, and 95% of the responses were people just going "der! It doesn't work" and Andy going "What doesn't work?" And then going "The firmware!" And they'd go around in circles as no one could ever give information, and Haltech couldn't fault things on the bench, (especially when people wouldn't give any specifics).   Many moons ago, when Andy was back at e420c stage, he reached out to me, and asked me to test different plug and play looms for him (already had an e420c in the car on his V1 PNP loom). And he kept asking me, as I was competent enough to be able to give him some specific feedback on what was/wasn't working, how to replicate the faults etc, and work through things with him. Most people are terrible at answering the questions they're asked, or being able to provide quality feedback other than "it doesn't work".
