All parts were to suit MY01 WRX, but some certainly will suit other cars.
A change in personal circumstances has dictated the sale.
You want to build a reliable 10 second car? Here you go.
USDM STi EJ257 2.5 litre Engine
Semi Closed Deck Block
CP Forged Pistons
ARGO Forged Conrods
ARP Conrod Bolts
Balanced and Nitrided Crank
Ductile Sleeving
O-Ringed
Built to handle 30 psi and 8,500 rpm
0 km’s since build
$8,000
MY99 WRX heads
No cams
$650
Innovative 60-1 Ball Bearing Turbocharger
Stage 5 rear, polished compressor housing
Brand new, 3 month warranty as I haven't even picked it up yet
$2,200
HKS Exhaust Manifold
Heatwrapped
Used, but very good condition
$1,200
Halfya F1 Muffler
Polished, very loud, $700 new
$400
MRT Fuel Rails
Brand new
$250
SARD 800 cc Injectors (GTR Injectors I believe)
Brand new, bar one being flow tested
Require MRT Fuel Rails on WRX
$700
Bosch 044 Fuel Pump
Brand new
$350
Aluminum Surge Tank (2 Litre I believe)
Brand new
$200
Unichip Wire in ECU
$550
APS Cold Air Induction
Second hand
$200
19 x 7.5 inch Racing Hart CR rims with 235/35 Falken tyres
Tyres in good condition, rims are very good condition
$4,000 or $3,300-$3,000 trade with stock MY01-04 rims and tyres dependant on condition
SOLD
Whiteline Group 4 Coil overs
Custom front springs on the front
Comes with normal front springs too
Absolutely awesome handling and ride quality
$2,500
CUSCO Front Strut tops
$300
Whiteline Front Strut Brace
Polished and chromed, never used since
$200
STi front foglight covers to suit MY01/02
White, good condition
$100
C West front lip to suit MY01/02.
Fitted and painted last week
$300
CP Forged Pistons
ARGO Forged Conrods
ARP Conrod Bolts
Ductile Sleeving
O-Ringed
0 km’s since build
$8,000
MY99 WRX heads
No cams
$650
$2,200
Heatwrapped
$1,200
Halfya F1 Muffler
$400
MRT Fuel Rails
Brand new
$250
$700
Bosch 044 Fuel Pump
Brand new
$350
Brand new
$200
Unichip Wire in ECU
$550
Second hand
$200
SOLD
$2,500
$300
$200
$100
$300
https://www.sau.com.au/forums/topic/56852-fs-engine-turbo-suspension-etc/
Some friendly advice for you. I assume you have posted this stuff on the WRX forum but the RS liberty forum is another excellent place to sell this stuff as most of it is compatable with their cars.
http://www.rslibertyclub.org/forums/
