Hi people,
I have installed a 4ch amp into my car and it is an Old School one that a friend just gave to me and seems to work rather well and am very happy with it. However, I want to add a sub as the ol 4" splits and 6" in the back dont offer me enough kick. I have a 15" JL Audio Sub that i had in my last car and i want to use it as i couldnt stuffed buyin another one.
MY plan is to run 2ch bridged into sub and other 2 running my splits. 6"s will run off my head-deck.
Question : Because the Amp is OLD it does not have a high low pass switch on it, and i am wondering if anybody has heard of a High Pass Filter that is available that i could use for my sub (much the same way as the cross overs work for my splits) ??
Does anybody have any ideas?
Appreciate any feedback !
Cheers
HAro
https://www.sau.com.au/forums/topic/56880-high-low-pass-filter-question/
First, you need a low-pass filter for the sub (the one that lets the low frequency through). I am pretty sure if you go to any car audio place they ll be able to get you a stand alone filter. I would also recommend high-passing the speakers as well. This will allow the speakers to be much louder in treble and midrange.
Alternatively you can construct your own filters from a coil and a capacitor. You will need to research how to do this to get good sound quality. I made a set of high-pass filters for my 4" speakers and the result was awful, the bass filtered out but the distortion was pretty bad. This however will probably work on a low pass filter since the distortion is mainly in trble.
Go to your audio store and i am pretty sure they ll help you.
Low pass hey?
Sounds like a plan, i will roll out to a Jay car over the next few days, these forums are tops for gettin some answers quickly.
Thanks Guys, now all i have to do is organise a time to pull apart all my "install" and get into it!
Cheers
Haro
OK... Done like a dinner !
The low pass filter from Jay Car was about $30 so thats ok. Didnt have to build it or anything, just bought it off the shelf. Works a treat. Now i just have to work on that bloody engine whine noise that soo many people get. I think i just will try a better amp.
Thanks for your help people.
HAro
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
