  • Replies 169
i dont obey laws i make em lol. sorry sinista i had a hard time trying to put em on took me 4 hours and not gonna even try to take em off only for a flat tyre and that is no suggestion for u to go give me a flat ok :P
I guess I can have mine ready by then...
not much tho just a 32 GTR, Stock white rims, lowered, BIG Exhaust, Pods, Bright Yellow/Gold Pearl, F/Bar, and me..... married..... with children......step back ladys... hehehe... very joking...
but can have car available if needs be.
hehehehehe well what can i say. seeing i am the youngest i think i should pick first. and jnj_r is there any chance of posting pics of these 12 girls lol so we can choose before we bitch fight when we get there
ooooooh, a bitch fight hey sexygtst??? dont want your hair to get messed up..... do you?? hehehehehehehehe
well obviously i dont want my hair to be messed up need to impress the ladies :aroused:
Sorry no pics... being their year 12 formal I'm sure they'll all be dressed up and looking good, but I haven't even met almost all of them (let's just leave it at that bearing in mind one of them is my sister!)
Just confirming again:
jnr_j
Timbar32
race_snooze
Sinista32
Skylinegal
sxygtst
Should only be 2 passengers each if we get 6 cars. Sounds good.
For whoever's keen I'll buy a couple of rounds somewhere afterwards too.
John
well i am in regardless beer or no beer. u just have to pm me the address and ur phone number so i know where i am going. do we pick them up aswell
They're all going to be at my olds place - so we'll all meet and go from there.
It's in Weetangera, I'll pm everyone details & phone no later in the week.
sexygtst reminded me that I have had 2 bitch fights worth mentioning: the first was at a club while aiting for john farnham to appear. A girl bumped into me once too often on the dance floor, so I punched her and ended up getting thrown out. Didnt see farnham, and also stumbled home with one heel a lot higher than the other (picked up one of hers by mistake)
2nd one was at a rodeo in qld, punched a girl for calling stu a nasty name, so I had to thump her as well, (she made me do it haha). Stu ended up fighting with a couple of guys and our dog decided to bite anyone that was hitting stu. Stu got arrested and taken away, and get this,,, the cops said if we didnt restrain the dog, he would be arrested too!!!!! So stu slept in the cop cells, dog and I slept in the back of the wagon, and next day when on the way to bailing out stu, got a speeding ticket!!!
Ohhhh, such fond memories.......hehehehe
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
    • Good to know, thank you!
    • It's a place for non car talk. There's whoretown which is general shit talking. But also other threads coving all sorts of stuff(a lot still semi car related)
    • Looked it up. It sounds so expensive lmao I'd rather not. Awwwww but I just love that sound
    • If you want the screaming "weeeee" sound, just let the gasket between the exhaust manifold and the turbo break a little. It'll go "weeeeeeeeeeeeeeeeeeeeeee" everytime its on boost...
