$13,000 R32 Gtst, Manual.
** UP DATE** read my last post.
As some clown backed into my car, at my work car park. I'm looking to sell it as is. I have two quotes to fix the damage. One for $1100 and the other for $1400.
The only damage is to the front guard, front blinker (right hand side) scrape on the front bar, scrape on the bonnet and a minor dent/scrape on the right hand rear qrt panel.
I only have pics of the front damage, and will only take pics of the rear guard for people with genuine interest, and take the time to contact me, as I don’t have the time for poor P plater wannbies.
Specs as follow.
1993 - complianced 2003 (I'm the 2nd aussie owner).
White with a sunroof.
Turbo manual.
Fully adjustable Apexi coilovers.
Apexi springs.
Apexi AFC and boost controller.
Apexi pod filter.
Turbo Smart BOV (Brand new).
GTR fuel pump.
3 inch turbo back exhaust.
Stock R33 rims with 70% 225 tires.
MP3 head unit with 400wt 6x9's
Short shit gear stick.
Genuine GTR front bar, grille and bonnet.
Type M side skirts and rear pods
Wingless boot.
I've had the car around 12 months, as I needed a daily driver when my road/race car was sold. This is my 5th import, and gets serviced every 5000kay.
The car is due for motor/gearbox/diff oil change - Which I won’t be doing. Car need's new tires, but will pass RWC. I'm selling this car with a RWC.
As of today 25/11/04 it has 134,xxxkay on it.
If you have any questions contact me.
In QUEENSLAND.
[email protected]
 Share
    • Hi there, after a quick google search I found this topic as I am also relocating the battery to the boot of my 1998 GTT. I was just wondering how you got on with installing the re-routing and specifically the installing of the harness protectors? How do they attach? Are they just a simple "click-in" affair, or do they attach with bolts? Does the GTT have all the necessary fixing holes for them, for example, where they locate on the chassis? Any help you can provide would greatly appreciated.
    • Thanks mate, yeah I've heard that alot and i am definitely regretting using the 25 Loom now, i have gone through and traced all the plugs from the 20loom and re wired them into the 25 loom, I have currently got Crank, Fuel and accessory's working, just need to finalise the loom and run the wire for the Ignition (Spark) and it should be running, will update if i have any luck.
    • Cheers lad, when I head over there I'll give it a shot.
    • Stock less likely to carry one like that than urethane, but still can, especially if the bolts are not as tight as they should be. If it's making that much noise you should be able to use a hose as a stethoscope> stick one end in your ear, crouch down and wave it around the various possible noise makers and get someone to lift the front end at the guard lip.
    • Broken actuator rod. Could be one of a couple of them broken. Or, it's locked and the central locking actuator is broken/stuck or the actuator rods between it, the lock and the key barrel are jammed or broken similarly. You'll probably need a locksmith/mechanic who is experienced with using slim tools to reach down next to the window glass to manipulate the mechanism. That's assuming that it is not so severely jammed/broken that nothing useful will move.
