rb25det APEXi POWER FC ecu
used for 2 months in car
just plugged in
never even tuned it at all
still have box and instructions etc
also comes with hand controller
$800 ONO
0431 584 504
in sydney
thanks  :headspin:
Dude, ill pick this up off you tomorrow for 750, ill come out to u
My number is 0423 324 906. The guy who just msg'd you
