My front and rear tyres clear my guards ok, but if i try to go any wider i have probs with rims hitting control arms etc etc.
So has anyone looked/installed aftermarket arms and realised they have an extra inch or two clearance for wider rims?
I suppose im dreaming of being able to fit 265/17s , 17x9s on the back of my R32 GTST, want to improve my corner speed at the track:)
https://www.sau.com.au/forums/topic/56931-wheel-clearance-aftermarket-susp/
ive dummy fitted 9.5" rims to the rear of my r32 Roy...same offset as i have on there now, (going from an 8" to 9.5" rim) and it clears the suspension the same.
I was told i could get away with it if fitting say 245 wides on the rim...but i dunno if that would help you on the track :)
265's....may be pushing it a tad.....255's....maybe...just :)
i think i should have the rims you are using, and you can get another set that won't hit the arms.
sorry that was of no help :)
When its hitting the control arm is it also too close to the guards? If not you might be able to fit it by changing the offset.
Also, make sure you check with the tyre you are trying to fit. 265 r tyres are *much* wider than 265 road tyres :)
One of our cars will probabley run 17 x 9 this weekend. Will be rolling the guards, but not sure on tyre sizing yet.
I think you can over tyre them and we tend to stick to the Dunlop tyre/rim size register.
Will let you know the outcome.
TT
....but I will check offset and rim type.
We ran 5 laps at Symmons today for a shake down and no worries. We have rolled the lips and have a set of GTR guards to go on, but not needed.
I think that 8.5 would be the go all round, but nobody seems to make 'em.
we are hunting tomorrow, so will let you know.
265's seem to be over the top... What are you going to run 'em on, an old 20litre drum LOL
Cheers
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
