Hey everyone!
Guest NismoWithNos
Hey Tasmanians... About that Yellow skyline... If that is the one that hangs out around Launceston it isn't actually a GTR.. it is all rice .... very rice lol...
And Also... I got some proposals for my car.. I messed with the picture for a couple of minutes.. although as dodgy as the picture is, u can see it has potential haha....
Should be "lowering" the car this week..
Steve
https://www.sau.com.au/forums/topic/5695-hey-everyone/#findComment-88746
You guys are really pathetic... maybe try reading the Message first... I SAID it was a dodgy job.. I couldn't be bothered spending much time editing the picture. It took me about 3 minutes... AND i was not bagging out the R33.. I was stating an ACTUAL FACT that if that is the car that hangs out around Launceston.. then it is not a GTR it has GTR Badges and that is all.. it is a GTS-T....
No, This r30 is not my dream car, simply a fun project car. I would rather a 300zx but I don't have the amount of money I would like to spend on one yet....
Next time read the text..... Don't go blowing your horns and getting ahead yourself.. for stuff sake lol...
Steve
https://www.sau.com.au/forums/topic/5695-hey-everyone/#findComment-89520
Steve
https://www.sau.com.au/forums/topic/5695-hey-everyone/#findComment-89525
Guest BoatsRbttr
:shake:
Hi guys I am a new member having a look around.
Read through this stuff and I would like to mention that I have seen that yellow skyline, I don't think RICE is the word here Steve, I pulled up next to this thing in town the other week, hearing what sounded like a touring car, I looked at the front of his car noticed Water pissing out of it, only because this pretty sick Under car lighting kit thing was highlighting the ground like all hell, so i said mate you might have a problem there, he shook his head and said "the only problem with this car is keeping it straight!!" and he put the thing absoluetely sideways around the corner and snapped third i think, burning tires like no tommorrow, it was poetry in motion. Don't know muck about this Rice stuff but i understand it is a bit of an insult so i reakon their right to think your a bit of a tool. Any way I still think boats are better! ;)
https://www.sau.com.au/forums/topic/5695-hey-everyone/#findComment-89637
OK.. let's clear up some things... I never said I didn't like the car.. It is nice and all.. I didn't think me calling the Badges rice would be so offensive to you all.... I was told that the car was a GTS-T not a GTR, therefor I called the Badges Rice.... It is a nice car but I was simply stating that that car is not a GTR... And if your car is a GTR, then I must have the wrong Car....
Intercooler sprays are cool and neon lights are good too....
No offense intended aye...
So is yours a GTR or not? I saw another Gunmetal R33 GTR in town today... Love em...
Later
https://www.sau.com.au/forums/topic/5695-hey-everyone/#findComment-90029
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
    • Correct. The ECU cannot read oil temp. (Well, I think it probably can in some situations. I did have the thought of potentially repinning the ECU when I was doing oil pressure). I am using this into the MPVI dongle, so that the MPVI dongle can read oil temperature. It is attached to a VDO gauge which is obviously calibrated to whatever curve the sender actually is using. This would be easy if I could setup a table of voltage to temperature like many sensors, but it appears I cannot do this and can only setup the transform rule which appears to be Input (voltage) x Multiplier, and add an offset. This to me means it MUST be linear. So it may be a complete waste of time wiring this into the ECU. The idea was that the MPVI3 has standalone logging. I wanted to use this instead of a laptop with serial cable (for wideband) for long datalogs. Given the wideband also has electric interference, I may never trust this either in a world where the serial wideband and the analog output wideband do not agree. Last time I did a trace I could see the two wideband traces follow each other, but one was a little leaner than the other. I plan on playing with voltage offsets and actually driving the thing to see how close they correlate. If they never correlate... then, well, maybe I'll never use either. Ideally I'd like to have the Analog wideband read ever so slightly leaner than the serial one, because the serial one is 'correct'. Tuning the car to be ever so slightly too-rich would be the aim. Not needing to have a laptop flying around in the footwell connected with cables is... an advantage. About the only one from the forced upgrade to MPVI3.
    • Hopefully not, since he knows the fuses work ha ha ha
    • I don't think he's got it on a gauge and on the ECU. I think he's got it on the gauge and on the HPTuners DAq thingo. Remember, we're talking about oil temp here, not something that the ECU is actually interested in for its own sake.
