Guest JPD Baraba
hey guys
i am a member of sdu and i have been for a while
i joined on the tail end of a good era when like mined people who loved their cars especialy skylines used to just meet up and hang out. we would help each other out through previous experiances.
then something happend. i am not sure exactly when or why but the club execs changed and so did the direction of the club. at this point there were over 200 members. 18 months later there is only 80 or so. it was attempted to run the club like a business and this is where i belive it failed. people lost the passion for the club. but you guys are right someone wanted to make this the best and biggest club in NZ and they failed.
i joined cause i liked the idea of a skyline community and i love tinkering with cars.
i personaly have joined another club not because of spite but because i wanted to expand my horizons and like i said i just love cars.
i can see why people tried to clean up the forums because they are the public face of SDU and that face was getting put through mud.
i personaly hope that the club can change back to its rots and be an enthusiasts club. this is hard because there is a lot of work that needs to be done and usualy it is volunteer work and nobody seems to want to do it.
i also hope that immature shit stirrers grow up and learn to respect other and their property.
Danijel
https://www.sau.com.au/forums/topic/57-sdu/
And you are posting that here because??? :?
I'm assuming this is Bizkit, dude we have nothing against individual people at SDU but we Aussies feel a bit jipped that we had more forum members and still couldn't join the club.
I think you'll find just by looking at the size of the Aus Forum, we aren't all red-neck mullet wearing yobbos and we have valid information to give out. But we are also social people hence the reason, I think so anyway, why the "big split" happened.
You can keep your 'information source", if I need something I'll know where to look, but don't come here feeling sorry for SDU.
BUT if you are here to have fun be merry come on in!
https://www.sau.com.au/forums/topic/57-sdu/#findComment-1392
hmmm don't know what to say. but seems like some ppl got greedy. so they took the general forum away. you can do that stuff here :)
i don't see the problem. there where rulez they weren't followed so they enforced them. u gotta live with the consequences of your actions.
i'm ready for u squizz blast away.
https://www.sau.com.au/forums/topic/57-sdu/#findComment-1405
  Quote
Aussies feel a bit jipped that we had more forum members and still couldn't join the club. [/quote:0ecac8e569]
I don't feel jipped Squizz. Why would I want to join a club whose rules are not accepted in Aus. Unless all you wanted was to join so you can receive a T-shirt and a sticker.
Me, I want more out of a club. Like racetrack meets for eg. No way will CAMS let you set rubber on a track because you are a member of a club that's overseas. (at least I think not :? )
Oh and ummm, re-read Bizkit's post. I don't think he was sympathising, just stating the obvious.
https://www.sau.com.au/forums/topic/57-sdu/#findComment-1406
  • 2 years later...
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
