Hi
Well 2day i got of my ass & did something about my current HAI Hot Air Induction problem & made my cheapy CAI panel.
I started off with some cardboard & cut a ruff shape arond the Pod to what will be my CAI box,
I then went down Clark Rubber & bought some Heat Shielded Rubber & a 12 pack of Clarks Choice condoms *nar j/k* I then went to Bunnings & bought some 90mm Plumbers pipe & 2 * 45 Degree curves, oww & some aluminium flyscreen too.
Got home, hacked up the sheet of rubber based off the cardboard & fitted it in around the pod. I then cut out another piece & placed it ontop of the pod. I then attached the top piece of rubber with some wire attached in 3 places to keep it in place.
Next was to cut the pipe to the right length & place it under near the wheel with my hand, make sure it fits. Ok thats done, i want to filter the pipe too from all those flys & shit so i placed the flyscreen over the pipe & only thing i could really think off to secure it was a zip tie, so on goes the zip tie & then cut off excess flyscreen. I dont actually know how to secure this pipe under there yet so hopefully somebody might be able to suggest something.
Ok so its all done now? Drive time!!! The car was defiantly pulling very hard, much harder than what it was earlier but that might also be because it was another few hours later into the day when the air is a little cooler. 7psi was very fast but i thought i better try 12 pound anyway, 12 pound pulled like a muther f#cka & put it back down to 7 right away, i dont wana die yet.
So yeh, i'll take the car for a drive again tomorrow around 1, 2 pm when it is the hottest outside & I'll know for sure the difference in power. But im defiantly thinking theres going to be quite a noticeable difference. You can feel the heat on the outside of the panels & the bonnet is so much kooler over the pod now. It used to be really hot but now its just like light warm.
I've attached a heap of pics so u know what im on about. I went & showed my m8 & his chic & they went "ahhhh thats dodgy". I was all shutdown coz i was pround of it. I'd rather something that works better than it looks. Anyway this chics grandfather is meant to be a pro with sheetmetal so i spose i might end up getting something that looks better. But im very happy with it for now, just want that pipe attached in under there near the wheel somehow now!
https://www.sau.com.au/forums/topic/57016-my-cai-box/
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
