im tryin to get rid of some parts so as an interest to the forum ill give a 10% donation on each item sold...
*** pair of r33gts-t front guards, no gt badges, perf. cond- $100ono
*** perfect r33 gts-t type m rear bar- $100ono
*** r33 gts-t ecu- $100ono
*** r33 gts-t AFM- $100ono
*** Z32 afm with brand new tomei plug, perf. cond. -$280ono
*** red leather momo race gear knob and red leather gear boot- $50
*** 1 checkerplate for driver side, cant use on passenger side due to hump-$20
*** left over mdf wood (16mm) more details on request- $offers
*** 3 guages, some japanese brand (water temp, oil pressure, amps)- $15
*** few wheel nuts (about 20, some chrome some not)- $offers
MISC Stuff
*** laminated rx7 poster- $10
*** brand new undercoat spray can (was goin to be used to undercoat dash to
get sprayed but never started it)- $5
*** brand new nokia 3315 in the box, unlocked, with boost pre paid starter
kit with $10 start...-$50ono
*** nokia 8250, with box, charger, handsfree, not orig. cover- $100ono
*** another boost start up kit with $10 free- $10
all i can think of atm, but theres probs some other stuff...
pics available on request for all parts...
cheers...ben.
https://www.sau.com.au/forums/topic/57018-donation-sale-r33-and-misc-bits/
