i have a kakimoto stainless exhaust cat back, and it is surposed to keep the DB level of the exhaust down by 7DB i read. it came on the car from japan. its on an R33 GTST. it has a nice note and sound but its quiet enough to keep the cops off your ass for noise polution.
1300 is way too much money to spend on a cat back, i would not buy one at all.
instead i would buy a xforce stainless steel turbo back exhaust system. u can get them for 950 (not delievered, add about 70 i think for delivery)) including hi flo cat and muffler with adjustable silencer.
I agree
I got one of those xforce turbo back systems from ebay about 6 months ago. Full stainless for about 1000 delivered. great note and easy to fit.
hey is the adjustable part of the muffler removable altogether?
is there a big difference in noise/performance when u open/close it?
The adjustable part can be removed easily with an alan key - one screw.
As soon as I received the system I removed the silencer and have never driven with it on so I couldnt tell you from experience.
I reckon you would notice a slight difference in performance as the end piece would be more restricted.
It sounds great especially with the hks pod at the front.
:cheers:
The exhaust on my '33 has a blended dumppipe (seperate wastegate pipe, very neat), hi flow 3'' cat, full manderal bent 3''system, 7'' rear muffler ( look sweet) , silver ceramic coated dump and front section down to cat - all done for $1600 at exotic exhausts in Brisbane last november. Drive it in, pick it up in the arvo. Sounds a lot better, and even better, goes better!
Cheers!
Or one better, have a mate whos 4th year sheet metal apprentice and all he charges is the price of the 180degree mandrel bend :headbang: mates rates :rolleyes:
I just got my cat back 3" redone alot straighter and removed the resonater for $50 (used the old muffler, which needs to be repacked)
it pulls more at top end, ide say its gained a few kw compared to the last 3" cat back because it was very bendy and had an old rusted resonater
pics in gallery :alien:
    • Well some mostly good news and some slight bad news.  Good news is cylinder 6 did in fact only require a honing and I'm good to run my 86.5mm pistons again. I should also get the block back by end of week. Bad news, had a few surprises pop up. First, main and rod bearings were trashed. No sign of any heat damage. I knew right away what caused this... I had not packed my oil pump originally and spent a lot more time than I would have liked cranking the motor to get oil pressure. It sounded fine once started so I chucked it up to luck and forgot about it. Luckily rod and crank are fine and just need new bearings. Engine builder agreed that this was the cause.    Another surprise that carbon covered up very well that I didn't catch, something got sucked up and went through cylinder 1, 2 and 3. Luckily this was no cause for concern, just needed a bit of cleaning up. Valves look fine but he will vacuum test the head this week to confirm. I'm presuming this was something left over from welding my intercooler piping, but we'll never know. I'm going to thoroughly reclean everything.    So all in all, happy the motor is fine, and I'll get it back much sooner than expected. I'll also be taking the time to convert my WMI system over to direct port. I'll snap some pictures of that when the parts come in.
    • I understand, thanks. Yeah I wouldn't want the car to tip over, I'll try and use the sills, I don't want to risk smashing the chassis rails. I ordered some rubber pucks that have a hopefully big enough slotting. If the front right gives me trouble I can always just make a wood block. I'll measure and inspect the sills closer once I actually take the car up. I hope so, but the rubber blocks I had in hand so far were pretty damn firm, if they are that hard they won't give much way. I'll let you know what happens. Angle grinding rubber isn't one of my favorite tasks. I'll probably start a build thread soon, for my own documentation and "log" as well as sharing what's going on with the car.
    • Kinda something I have been thinking about.  To be honest, we bought it already driving like that.  So there's no telling how long it actually has been driving like this.  Hopefully damage is too bad when we drop the pan.   I am having a hard time finding a site that sells the solenoid for the 5 speed auto, do you have any suggestions?
    • That'll be most likely down the road...  LOL
    • a stock / option or aftermarket?
