Howdy All,
Just a bit of info for all fellow Stagea type people. And that is that the fuel pumps on the RS4's aren't the same setup as the ones on the R33's.
I went to change mine today, undid the big black plastic locating ring, pulled the cap up and there was only the fuel gauge sender hanging off of it !!! The pump is mounted to the right/bottom side of the fuel tank. Not like the R33's were the pump is mounted to the big cap thingy :)
Soooo, I could be wrong here, but I would say that we'd have to go external if we want to upgrade the fuel pumps, as getting to the factory one down the bottom of the fuel tank is gunna be close to impossible :(
J
P.S. - Anybody want to buy a Walbro internal for $150 + postage :kick:
https://www.sau.com.au/forums/topic/57066-stagea-fuel-pump/
Interesting.... And the reason I say that is in the Nismo catalogue the 260RS pump is listed as the same as the BNR32 (not BNCR33). Is the tank different, or????
I was considering the R32 pump in my car as a first choice, but it seems that matters may be slightly complicated.
https://www.sau.com.au/forums/topic/57066-stagea-fuel-pump/#findComment-1103389
You have to be able to get to the pump to service it. There must be a way. As for the Stagea tank being the same as the R32 tank, my Stagea tank is molded plastic and the R32 tank is fabricated steel.:cheers:
https://www.sau.com.au/forums/topic/57066-stagea-fuel-pump/#findComment-1103854
Ahh, very good.
Was it difficult getting the factory mount/bracket out ? When I had the big cap off, it looked pretty damn hard to get to the mount/pump to get it out.
I was going to take a photo of it but I was a bit worried about using the flash around the petrol.. lol
J
https://www.sau.com.au/forums/topic/57066-stagea-fuel-pump/#findComment-1106193
    • Speaking of diverting threads, my second ever NISMO purchase…. I think they look pretty classy and just wanted to share 😅   PS: 1st was the oil drain plug 😂
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
