i have the consult to laptop/computer serial cable and software, its not the "nissan consult" but it uses the same protocol and obtains the same data. the proper nissan consult is like $15,000 and is only for use with nissan staff you can't buy it, and you wouldn't want too anyway. i got the consult data cable for $120 delievered
pm me if you want any more info
I'm interested on this consult. What ECU / vehicle does it work on? Got an R34 25GT Sedan that been having the Check Engine light coming on. Couldn't find the screw on the ECU to switch it into Mode II Diagnostic.
gaki.....the vehicle has an on board diagnosis function.....it is activated by earthing one of the wires in the diagnostic connector ....you will see a little door/panel that unclips from on the lower steering column trim....thats where it lives....i cant remember which wire it is but you just switch the ignition on and earth it momentary and it enters diag mode.........to check which one it is....just check for positive power and you know its not that one.....you cant harm anything from earthing something thats not live....anyway once it enters diag mode the lamp will start to flash....to exit just switch the ingition off
Is there any difference at all between the Nissan CONSULT and the one you have? Does it have exactly the same functions?
LW.
Why do you guys insist on using the consult?????  :confused:
From what I understand, CONSULT can give you a little extra information and make it easier to diagnose issues. The whole flashing light sequence thing is difficult to use.
In my case I have an issue with HICAS and while I can get it into diagnostic mode, the flashes are bizarre: there is short flashes, a medium flash, and long flashes.
For $120, perhaps CONSULT is a better option.
LW.
    • I recently got their dbw 74mm throttle body and pedal kit. It is sensational quality especially the wiring harnesses. Unfortunately I can’t answer u about the fitment to stock inlet manifold as I’m going Rahjab Racing forward plenum. Only one thing to be careful of is understand u have to pay gst and import fees if your purchase is over $1,000 in one shipment.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
