Hey guys.. after all the recent incidents on the road's i feel i need to get my cars problem sorted.. (its a R33 GTS-T btw)
ive had it 'droped' only a inch or 2 right around.. but ive only used springs. no other componants.
ive got a set of good quality TEIN springs.
but after this.. the car feels REALLY unsafe and insecure. it feels to jerk around, its really bouncy. and feels unstable. on the highways doing 100km/h it doesnt feel very sound.
on boost if you hit little bumps on the road it looses traction because it jumps around so much.. clunking and all sorts of shit.
i dont have the cash right now for a full upgrade from whiteline or anything but am willing to spend 500 or so for the time beign to fix.
any idea on whats wrong or what other parts i need?
sorry for the long post. Thanks guys!
https://www.sau.com.au/forums/topic/57078-suspension-need-some-advice/
sounds like the springs you got are way too stiff, which is usually the case with jap aftermarket springs, it would have been a safer bet to get some whiteline springs...or local ones where u know how stiff they are..
stiff springs in conjunction with your (probably?) stock shocks = adding to the problem..
so if i were u i would change the springs again.
How "adjustable" is your suspension? It's possible that the weight distribution is all wrong after the ride height was adjusted.
It's probable that the shocks are not matched to the springs. Stiff springs and soggy shocks don't really work well together.
aftermarket shocks will probably help,
but all tein springs ive seen are wayy to stiff so yeah in combination with the probably worn shocks things are not working.
new shocks will cost u more than 500 though...
also your bushes might need replacement, (made apparent by new stiff suspension)
Hi, with what sik said about most jap aftermarket springs being too hard. some are hard and some are soft. Some coilovers are also adjustible from soft to hard.
Tein make a very nice range of combos. Some offer a very nice ride, still with feel. Others are much harder.
The problem is (i'm very interested, so i've had a play and own many many sets of suspensions, so I'm no noobie):
People just go, oh, I wanna lower my car, so they buy a shorter set of springs, like king low or super low. But these aren/t designed for the stock shocks.
By reducing the travel of the stockos by 2 inches, basically, think about it, i'm not being sarcastic, but the shock has a lot less travel and damper than it was designed for. What you need, is something that was designed to operate in those lower conditions. Take a look at the tein site - www.tein.co.jp and notice how their lower shocks have a much wider tube, scuh that it actually can still damp when it's shorter compared to the stocko. Just to prove my point, the stocko will keep hitting the bump stop and basically get destroyed in a couple months.
sik, you were 100% on the money, new shocks are definitely needed, and probably the bushes will be worn. No biggy really, don't stress, they aren't that expensive.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
