Hey all i was wondering if anyone can help me.
Just imported my car and its finally fully registered and on the road.. its done 103,000km, what should i change??
I think the compliance ppl changed the engine oil, filters etc... but i couldnt find a sticker saying the timing belt has been changed... does anyone know if the timing belt is expensive or where i can get one from?
Thanks.. also is it crucial to change it???
sorry for the stoopid questions
Thanks
https://www.sau.com.au/forums/topic/5710-just-got-car-what-to-change/
Get the timing belt looked at for sure, i couldn't reccomend anyone in particular, but if you're stuck most nissan dealerships should do it (might pay a bit though). But definately get it looked at, they should be able to tell if it's been done or not depending on condition (cracks/wear/tear)
Mine had a little "plate" stuck to the top of the cambelt cover or whatever it is, and it says at what kms the belt was changed.
Have a look there, yours might have one too :D
Otherwise yeah, any mechanic could check it out for you.
If you can't find the sticker saying it's been changed then err on the side of caution and change it. It's meant to be done at 100000km or thereabouts, if that baby snaps your engine is going to be up for some serious repairs.
Belts are around $110 from Nissan (genuine), or around $30 (I think) for a 3rd party one from your local mechanic. Labour to fit should be around $150 or so, if you don't wanna do it yourself. It's a medium difficulty job, even though I'm sure I could do it if I absolutely had to, I think I would just pay the $150 and get a mechanic to do it. It's a once-every-5-to-10-year job after all.
Ask the importer what oil he used, if it was just cheapshit Woolies oil then change it again anyway, it's a small price to pay to protect your engine and turbo.
The rest of your fluids can probably wait, but change them as soon as you can:
Transmission oil (almost certainly never changed by any previous owner)
Brake fluid
Clutch fluid
Diff oil
I've done everything bar the brake fluid on mine so far, it was going to be done by Midas but I forgot to bring my wheel locknut key and they were too lazy/inept to bleed them with the wheels on. I've done it myself on other cars plenty of times with no problems/hassles so I think they were just being lazy. I might do it myself soon if I can get motivated enough.
    • I recently got their dbw 74mm throttle body and pedal kit. It is sensational quality especially the wiring harnesses. Unfortunately I can’t answer u about the fitment to stock inlet manifold as I’m going Rahjab Racing forward plenum. Only one thing to be careful of is understand u have to pay gst and import fees if your purchase is over $1,000 in one shipment.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
