Hi Guys
I have a friend who imports strut braces and I can get some good deal from him if I buy in bulk. This is the going rate
buy 5 for $70 each
buy 10 for $65 each
buy 15 for $60 each
buy more than 20 probably $55 each but we will see if there are that many takers.
Postage is usually $13
Here is the list of strut braces I can get
skyline
R33 front strut brace
R32 front and rear strut brace
Silvia
s13 front and rear strut brace
Supra
Fits JZ80 and 70 series front strut brace
Soarar
Fits on soarer twin turbo and non turbo front strut brace
If you guys are interested pm me or email me or reply to this thread.
Over the next few days/week I will see how many people are interested and let you all know what the cost will be. If everthing goes good I will then need the money from the buyers and I will get the parts and send them out to you guys. If everyone pays up quickly the buyers should get their strut brace within 7 days.
pictures
https://www.sau.com.au/forums/topic/57102-strut-braces-group-buy/
Email has been sent to the guys interested. The brace are going for $65 each. If anybody is still interested let me know and I can try to squeeze you in aslong as it is before the end of the week. Otherwise just wait for strut brace group buy No: 2
We are good to go, shipment is scheduled in for monday. For those of you who still want to purchase a strut brace or 2 the cost will be $65 each + 13 p&h for 1 $20 for 2 or you can pick it up. I will be getting the braces on the weekend so if you want one make sure you get incontact with me soon.
i know its a bit late, but interested in front 33.
where is pick up from?
live in brisbane
wow what a deal!
but for the fact i was offering these at the same prices (one is 85 del, two are 150 del) with no need to group buy!
ho/hum :)
Guest
    • Result of another R35GTR build. Similar specs as above except this is running our bigger size SS-2 profile option. Made similar power except this car runs on Pump 98 fuel. Build specs are: Nissan R35 GTR 2015 model stock engine and box. ETS street intercooler boost logi intercooler piping with tial bov, boost logi turbo inlet pipe ID 1050 injector DW 300C fuel pump Decatted oem down pipe and y pipe& HKS exaust 3inch intake pipe Upgraded actautors HyperGear SS-2 high flow option Final result is 639whp / 477wkws hubs, Ron 93 / P98 fuel at 20psi.
    • Duncan:- it affect both sides.  Driver side is worse.
    • That seems like a very special issue!  Does it affect both sides? Either way, I would disconnect the driver's side switch and see if it still happens, noting that might require removal of the whole door card which is a bit of a pain (it does on V37 and HY51)
    • MBS206:- The windows start to slowly open themselves. GTSBoy:- Battery is new since Dec.
    • I currently have a 2008 370GT Coupe, with the big brakes (Akebeno if I'm correct), and Its coming time to get new pads. Previously, I had a 2003 350GT Coupe with the stock sized brakes, not Brembos. I had custom wheels on it that were pretty open to the brakes, and when I first put the wheels on it, the rims where completely coated with brake dust. A few years after adding the new rims, I needed to change to pads on that car. I didn't do any research, but I told the mechanic of the problem with the brake dust. I also told him I didn't track the car or even drive around the streets harshley. But the dust was an issue. The mechanics changed the pads to a different compound, and the dust was GONE! The other change I noted was that when coming to a complete stop, instead of having to press harder on the pedal as I approached 0kph, I had to actually lift off a little to not come to a hard jerky stop.( My unfounded explanation is they became stickier as they heated by stopping ) Since I got my 370gt with big brakes, I noticed that that as I came closer to stopping, I had to press harder and harder to reach a full stop. I am not talking about hard, just harder. I brought the car in from another state, so when I had a blue slip done, I asked the mechanic what he thought of the brakes, and he thought they were brilliant. The only negative of these pads on the 350GT, was that they squealed when cold. So driving out of a shopping center carpark, it was a little embarrassing, as the brakes squealed, and I am sure people thought that I needed new brakes, when they were actually fresh. I have no idea of what type of compound they were on the 350gt, but whatever it was, I want to get the exact same on my 370GT. They weren't ridiculously expensive, and were replaced at the local JAX (which is no longer open), so I am certain they would be a pretty common big brand, off the shelf type/brand. My current mechanic suggested I need top get the rear pads changed soonish, but he suggested standard Brembo pads. Which I expect to behave the same as the current ones and not like the ones on the 350GT.  I don't think dust will be an issue on the 370GT. With the behaviour I describe above on the 360GT, does anyone have a suggestion of pad material that will act like the change I had done on the 350GT?
