hi all, i'm from SDU in auckland, there's a good possibility that i'm moving over to Sydney in a few months time, so would like to start get to know some ppl in SAU Sydney, been a very active member of SDU in auckland for a number of years now
i was wondering if its possible to bring my car over to Oz, the car is under my mothers and my name, and i've had it for nearly 1 and half a year now, if it does cost, how much would the compliance cost? and also what are some of the other rules?
i have a 1991 R32 gts25 converted to a turbo (as in slapping a turbo on the NA engine, hehe) 5 stud conversion and all
and one other question, if i cant get it complianced there i will sell it in NZ, so i was wondering how much R34 gtt go for these days in Oz, the pre facelift model, 1998-2000 ones, i like their front
thnx very much in advance guys
tovey
https://www.sau.com.au/forums/topic/57109-newbie-on-sau-nsw/
Welcome
If you can prove that you've owned the vehicle for 12+ months, you are able to import the car without compliance and so forth. However as its in your mums name im not sure of the procedure, or if that loophole exists. Otherwise you would unfortunately be unable to import the car as its too highly modified, and that I don't know if R32 GTS25 are on the compliance listing.
R34 GT-T go upwards of $30k AUD, depending on spec.
sweet as man, sounds good so far, i'm not fussed who owns the car in Oz, jst as long as i can get it there without too much hassle
one other question, is there a site i can go to, to find out what personalised plates are still avaliable? i'm wanting to put on the same one i have in NZ, RB25DE hehe :cheers:
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
