Hello,
I have a serious problem with my R33 V-Spec which is :
4WD, ABS, A-LSD lights on the dash are on !!
(All these lights appears at once, i think they are related to each other somehow!!)
there is no power to the front at all.. i tried every possible thing (wire tracing, fluid level, broken pipes, fuse) but it seems that everything is fine while the 4WD not working ... im ready to start over again and again but could someone tells any ideas of where to check or what do i have to do ?? i really need help !!
Note: the attessa-pro system (in the back) is flashing a code... one blink every 3 seconds and its contonuisly so can someone tells me what does that error code means ??
https://www.sau.com.au/forums/topic/57146-4wd-problem/
checking tires pressure is one thing but ....
as long as i start on the engine the 4wd,Abs,-a-lsd are on
means : 4wd, ABS they turn off for one second and turn on again ( after i start on the engine ) .. i think that the 4WD is working but there is something stopping or forcing it to not work .
lets assume that your right and the problem is with the tyres pressure or the size .. how come that they turn on as soon as i start on the engine ( ATTESSA-PRO ) wont know that before i move the car for a while !!!
the lights are on as soon i start on the engine .. it should be a connector which is not plugged properly or a broken wire .. ( I think ) !!! so could you tell me which place is good to start tracing to find the problem ???
thanks
https://www.sau.com.au/forums/topic/57146-4wd-problem/#findComment-1106516
    • Ah yes but were you responsible? In the time I've had it (just before Christmas) I spun off the track twice and drove into things twice, so four separate incidents.. in two outings. Luckily I have a full OEM GTR front end to put on which is hopefully not a precursor for further, future, more expensive mistakes to come. It is some consolation that anyone who would want to buy my Altia bar would have to paint it anyway, the guards, too. (if they can get over the asymmetry). Hopefully over the weekend I will disassemble and see how badly things are bent. From what it looks like, the headlight has actually just been pushed back and bent the headlight support (which .. somehow... crushed the guard in). I guess the headlight plastic is strong stuff.
    • These things happen And I believe "we, the people, who modify stuff, and actually use it, cannot have nice things" It's just a shame that it happened so soon after paint  I still win the award for quickly destroying newly painted panels I think, as my car came back from the paint shop all nice and shiny, until about 4 hours later when the boot was destroyed by a wayward locker that was blown around by the wind.... What doesn't kill you makes you stronger, and poorer.....dooh
    • This. And also, the rotor thickness is constrained by the calipers. Cannot be much thicker, if at all. Cannot be much thinner, if at all. New rotors are....fairly cheap. Turbo calipers can still be picked up for sensible money. Arguably, the best thing is to get R32 calipers and put them on mount spacers on 324mm discs. That's about the cheapest and easiest way to get quite large brakes that are essentially bolt on. And that's despite maintaining for years that the R32 calipers are not the best choice because they seem to be more flexy and creaky than the others. If you were prepared to put up with nasty little NA sliding calipers, these will still seem like Brembos by comparison.
    • A quick Google said 297mm..
    • Why would you not fit the biggest possible brakes?
