used kts large engine pipe will fit all gtr's
basically 3 inch from you dump pipes and meets at 3 inch at the cat (i assume muh larger than stock)
very nice havent had a problem on my car just upgraded to a big single turbos
very nice
yea baby!!!
250
um its not stainles has a few scraped but is in great condition
pete(padstow sydney)
0409226626
https://www.sau.com.au/forums/topic/57160-gtr-kts-front-pipes-250/
