I have an R32 gtr an after purchasing this 16 row oil cooler i am finding it hard to position it somewhere as there is just NO room..... It is a full g-rex kit with filter re-location an thermo.
Mine is mounted in front of the aircon condensor next to the aircon receiver dryer (drivers side of the bonnet latch). It's a tight fit but mine is not a 16 row - total measurements of the oil cooler on my car is about 250mm long by about 140mm deep and 50mm thick. There's no way anything larger would fit.
The cooler already came fitted to my car when I bought it (recently came in from Japan) and it also has the GREX oil filter re-locator kit. To fit the cooler they also had to re-mount the power steering cooler. I'm not greatly happy with the job they did, so I took the front bar off to see if I could move it elsewhere, but there is nowhere else unless I buy a smaller oil cooler.....
    • Ah yes but were you responsible? In the time I've had it (just before Christmas) I spun off the track twice and drove into things twice, so four separate incidents.. in two outings. Luckily I have a full OEM GTR front end to put on which is hopefully not a precursor for further, future, more expensive mistakes to come. It is some consolation that anyone who would want to buy my Altia bar would have to paint it anyway, the guards, too. (if they can get over the asymmetry). Hopefully over the weekend I will disassemble and see how badly things are bent. From what it looks like, the headlight has actually just been pushed back and bent the headlight support (which .. somehow... crushed the guard in). I guess the headlight plastic is strong stuff.
    • These things happen And I believe "we, the people, who modify stuff, and actually use it, cannot have nice things" It's just a shame that it happened so soon after paint  I still win the award for quickly destroying newly painted panels I think, as my car came back from the paint shop all nice and shiny, until about 4 hours later when the boot was destroyed by a wayward locker that was blown around by the wind.... What doesn't kill you makes you stronger, and poorer.....dooh
    • This. And also, the rotor thickness is constrained by the calipers. Cannot be much thicker, if at all. Cannot be much thinner, if at all. New rotors are....fairly cheap. Turbo calipers can still be picked up for sensible money. Arguably, the best thing is to get R32 calipers and put them on mount spacers on 324mm discs. That's about the cheapest and easiest way to get quite large brakes that are essentially bolt on. And that's despite maintaining for years that the R32 calipers are not the best choice because they seem to be more flexy and creaky than the others. If you were prepared to put up with nasty little NA sliding calipers, these will still seem like Brembos by comparison.
    • A quick Google said 297mm..
    • Why would you not fit the biggest possible brakes?
