g'day fellaws.
i have installed a stage 3 boost controller. but i cant set the psi's.
at all 3 stages the psi are set to min. but on ma boost gauge it shows 14.5psi at the 3 stages.
now i noe that 14.5psi is going to kill ma tubo and thats y i need ur help ASAP.
have a look at the pics. tell me if i left a hose out or didnt block a hose... or wrong way around.
wateva helps.
now its electronic obviously. so i got the wiring done by a mechanic.
im not sure if the stock solonoid should stay wired, and jst bypass the hoses, or disconnect completly?
thanks guys any help will be greatly appreciated.
https://www.sau.com.au/forums/topic/57179-whats-wrong-with-this/
Plumb your new ebc directly to the actuator and a point just after the compressor outlet or where ever the r33 gets it's boost signal from and bypass the factory solenoid completely. You can leave the solenoid hooked up but just make sure you block off any hoses that will cause a boost leak.
so i can completely remove the stock solonoid! great. there are no hoses going to this solonoid anymore! nothing to block
where is the actuator , i thought wastegate is the safer and more logical way to connect the ebc to!?!
jst cant figure y i cant set ma boost less dan 14.5psi...
:bs!:
Ah, thought you had the two in tandem as the new ebc is tee'd into something.
The actuator controls the wastegate so we're probably talking about the same thing.
So now i'm stumped because if you remove the facory boost controller the boost should drop as the wastegate is pretty soft so with the new ebc hooked up and switched off it should read about 6-8psi depending on other mods
mods = 3inch madrel bent turbo back [nismo], apexi intake & apexi bov.
its jst hooked up to the elec solonoid, stock one no longer is hosed or wired to anything! i tried wiring the stock solonoid but no diference.
the 2 blue hoses are the only thing conected to the new solonoid and the wiring to the controls in the cabin.... i have check the instructions and the hoses are going into the right coms, maybe this will giv u a beter idea.....
thanks bhdave...
The question is, is it a plumbing problem or an electronic set up problem.
The way I do it;
Eliminate the plumbing possibility first. Unplug the wiring from boost control solenoid, but leave the vacuum hoses. You should have standard boost, the only thing holding the wastegate closed is the spring rate in the wastegate actuator.
If you have normal (low boost) then it is an electronic set up problem. Reconnect the wiring and read the set up instructions. Set it up EXACTLY as per the instructions.
Hope that helps:cheers:
if it was electrical , wat would it be....
as i am sure that the ign, earth, blue ext, purple ext are properly connected, the graydoes not need to be connected as im runnig closed loop.
my only dout is that the mechanic connected the orange [boost sensor wire] in the wrong spot!?
any help'?
Don't worry about it, it's blocking the stock BOV return line as they have fitted an atmo venting BOV.
All you need is to tee into a boost signal point (basically any point between the turbo compressor outlet and the plenum will do, your diagram has it tapped into the fuel reg signal line by the look of it which should work okish) and a connection to the actuator. No tees in the connection between the solenoid and the actuator, just a single bit of pipe.
If it's connected this way and you switch off the ebc you should have slightly less than the cars stock boost and so you have eliminated any problem with the plumbing as SK has stated.
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
    • I have a r34 sedan 1999 manual converted need some help with my speedometer it only reads upto 98km and then stops currently still running the auto cluster any easy fixes no speedo drive is connected yet, if someone has a video for wiring up the manual speedo sensor with the auto cluster please send through
