g'day fellaws.
i have installed a stage 3 boost controller. but i cant set the psi's.
at all 3 stages the psi are set to min. but on ma boost gauge it shows 14.5psi at the 3 stages.
now i noe that 14.5psi is going to kill ma tubo and thats y i need ur help ASAP.
have a look at the pics. tell me if i left a hose out or didnt block a hose... or wrong way around.
wateva helps.
now its electronic obviously. so i got the wiring done by a mechanic.
im not sure if the stock solonoid should stay wired, and jst bypass the hoses, or disconnect completly?
thanks guys any help will be greatly appreciated.
https://www.sau.com.au/forums/topic/57179-whats-wrong-with-this/
Plumb your new ebc directly to the actuator and a point just after the compressor outlet or where ever the r33 gets it's boost signal from and bypass the factory solenoid completely. You can leave the solenoid hooked up but just make sure you block off any hoses that will cause a boost leak.
so i can completely remove the stock solonoid! great. there are no hoses going to this solonoid anymore! nothing to block
where is the actuator , i thought wastegate is the safer and more logical way to connect the ebc to!?!
jst cant figure y i cant set ma boost less dan 14.5psi...
:bs!:
Ah, thought you had the two in tandem as the new ebc is tee'd into something.
The actuator controls the wastegate so we're probably talking about the same thing.
So now i'm stumped because if you remove the facory boost controller the boost should drop as the wastegate is pretty soft so with the new ebc hooked up and switched off it should read about 6-8psi depending on other mods
mods = 3inch madrel bent turbo back [nismo], apexi intake & apexi bov.
its jst hooked up to the elec solonoid, stock one no longer is hosed or wired to anything! i tried wiring the stock solonoid but no diference.
the 2 blue hoses are the only thing conected to the new solonoid and the wiring to the controls in the cabin.... i have check the instructions and the hoses are going into the right coms, maybe this will giv u a beter idea.....
thanks bhdave...
The question is, is it a plumbing problem or an electronic set up problem.
The way I do it;
Eliminate the plumbing possibility first. Unplug the wiring from boost control solenoid, but leave the vacuum hoses. You should have standard boost, the only thing holding the wastegate closed is the spring rate in the wastegate actuator.
If you have normal (low boost) then it is an electronic set up problem. Reconnect the wiring and read the set up instructions. Set it up EXACTLY as per the instructions.
Hope that helps:cheers:
if it was electrical , wat would it be....
as i am sure that the ign, earth, blue ext, purple ext are properly connected, the graydoes not need to be connected as im runnig closed loop.
my only dout is that the mechanic connected the orange [boost sensor wire] in the wrong spot!?
any help'?
Don't worry about it, it's blocking the stock BOV return line as they have fitted an atmo venting BOV.
All you need is to tee into a boost signal point (basically any point between the turbo compressor outlet and the plenum will do, your diagram has it tapped into the fuel reg signal line by the look of it which should work okish) and a connection to the actuator. No tees in the connection between the solenoid and the actuator, just a single bit of pipe.
If it's connected this way and you switch off the ebc you should have slightly less than the cars stock boost and so you have eliminated any problem with the plumbing as SK has stated.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
    • Careful with posts like that around here without the flame suit on @cobo_11! 😂😂 My 330i journal is on here too. That car was so good and super reliable. We still have a 130i in the family which is almost identical to the 330i and easier to find in manual. It has also been almost faultless over the 6 or so years in the family.  I used to want an M car a lot more than I do now but if I'm honest and without trying to sound like a wanker, I can get such good performance and handling out of my 335 without needing to worry about all the crap that goes along with M car ownership. I don't need to worry about my bearings or subframe issues or the cost of replacing brakes or suspension or whether it has been impeccably maintained. And I can leave it places and not get upset when it's always filthy.
