  • Replies 69
are the people in this group buy still getting them? any idea when?
4 people got the kits. I was only able to get 5 kits :D
More kits are comming will be in australia in ~1month to 2months.
i installed mine last night, very impressed with the shift now. Its short and clicky but still smooth.
Has anyone else installed theres? If so did u use the plastic spacer that sits ontop of the ball on the standard gear leaver?
I ended up spliting it with a chisel (it won't fit over the ball or base of the shifter) and using it on the new one cause otherwise there was nothing to hold it down, u could lift it straight out.
yes you are suppose to split the plastic spacer. It is in the instructions which was mailed out. Well you actually suppose to split it with a little hobby knife.
I hope you put the little plastic bit on that was on the bottom of the original shifter.
somewhere in jan feb next year. But the the kit has no benefit in the GTR as the pivit point in the kit is the same as the GTR which is the basis for the 40% shift reduction.
Yeah the chisel works well too :( I put that plastic boot on too, works well, i've given it a good work out and its actually improved my shifts cause my clutch engages right at the bottom of the peddle.
Guest
    • Kaizo Industries put a VIN plate over where the Nissan plate would go. It was part of how they broke the law and attracted feds going after them.
