Let me start out by saying i don't know much about air con so if i say something stupid please correct me.
I've got a problem with the air con in my 90 R32 GTS-t. It keeps blowing one of the air con fuses (the one on the top row 4 from the right). When you turn the air con on the rev drop a bit then the fuse blows.
I've spoken to a couple of people about it and both have told me it's probably the clutch in the compressor. The guy i spoke to today said the only 2 things that draw current are the fan and the clutch. He said to disconnect the fan and see if it still blows. Unfortunitely it does so it looks like its probably the clutch. He said the clutch cant be replaced and that the compressor would need to be replaced.
So, does all this sound right? Do all skylines use the same compressor eg. can i get a compressor off a wrecked R33 or GTR.
How much should I expect to pay for a second hand compressor and how much to have the old one removed and new one fitted (I imagine a regas would be needed also).
I want to get this sorted out as soon as possible as ill be in Queensland for the next few months and its starting to get a bit warm.
Thanks,
Tom.
https://www.sau.com.au/forums/topic/57193-r32-air-con-problems/
yes, sounds like compressor.. working harder than it needs to, thereby using a lot of current.
2nd hand compressor anywhere from $200 to $500.. I think there are several different types of compressors that came even for same model, so you'll have to do a search.
Fitting who knows, but you could give it a try and then just get them to gas it.
    • Ah yes but were you responsible? In the time I've had it (just before Christmas) I spun off the track twice and drove into things twice, so four separate incidents.. in two outings. Luckily I have a full OEM GTR front end to put on which is hopefully not a precursor for further, future, more expensive mistakes to come. It is some consolation that anyone who would want to buy my Altia bar would have to paint it anyway, the guards, too. (if they can get over the asymmetry). Hopefully over the weekend I will disassemble and see how badly things are bent. From what it looks like, the headlight has actually just been pushed back and bent the headlight support (which .. somehow... crushed the guard in). I guess the headlight plastic is strong stuff.
    • These things happen And I believe "we, the people, who modify stuff, and actually use it, cannot have nice things" It's just a shame that it happened so soon after paint  I still win the award for quickly destroying newly painted panels I think, as my car came back from the paint shop all nice and shiny, until about 4 hours later when the boot was destroyed by a wayward locker that was blown around by the wind.... What doesn't kill you makes you stronger, and poorer.....dooh
    • This. And also, the rotor thickness is constrained by the calipers. Cannot be much thicker, if at all. Cannot be much thinner, if at all. New rotors are....fairly cheap. Turbo calipers can still be picked up for sensible money. Arguably, the best thing is to get R32 calipers and put them on mount spacers on 324mm discs. That's about the cheapest and easiest way to get quite large brakes that are essentially bolt on. And that's despite maintaining for years that the R32 calipers are not the best choice because they seem to be more flexy and creaky than the others. If you were prepared to put up with nasty little NA sliding calipers, these will still seem like Brembos by comparison.
    • A quick Google said 297mm..
    • Why would you not fit the biggest possible brakes?
