hi guys
got a strange problem with avc-r
for some reason the solanoid dosen't engage anymore
Ussually I will hear a click sound when the boost setting is changed from A to b
All the other sensor seem to still be working (duty ,revs ,kms,etc)
But no boost
it stopped working while it was on a dyno run ,
the mechanic found some pretty eratic spiking going,so i guess im lucky it happened on the dyno
so he set the boost to run of the actuator so i guess its pretty much running standard
I am not 100% sure how to test or where to start ,has anyone had the same problem or
Any idea why this may of happened
1994 gtst
haltech EK6
apex avc-r
https://www.sau.com.au/forums/topic/57209-avc-r-solanoid/
Perhaps check the actual tubing? I've never had an EBC but I thought there was some issue there if you didn't mount it close enough to something else it would spike up?
Also it may be worth testing the actual solenoid - now I'm not sure how much current it's expecting (i would imagine 12v) but if you're mechanically/electronically minded you could always try to set off the solenoid itself with an electrical feed like a battery - just to see if it clicks over. If it doesn't solenoid is busted.
*insert disclaimer here: never owned an ebc could be totally in the wrong*
https://www.sau.com.au/forums/topic/57209-avc-r-solanoid/#findComment-1106267
