hey guys, ive got my adj castor rods sitting here and im sure that ud have to get a wheel alignment when fitting them on. figured id kill two birds with the one stone by replacing whatever front bushes that can be replaced with new ones and having the wheel alignment only done once. does anyone know if theres any kits outthere like whiteline. does this sound like a good way to go about it?
cheers
https://www.sau.com.au/forums/topic/57249-front-end-bush-replacement-kits/
i was in the group buy as well for the KTS rods and already got whiteline camber kit for the front of my car. just give whiteline a call on www.whiteline.com.au and they will match the bushes to your car. Will deliver to your doorstep as well via express post. was planning on going cusco but like you said, it cost too much and illegal as well.
"illegal" i like the sound of that:D
sweet, yeah i think this is the same avenue that im gonna go too with the whiteline camber kit. are you running a rear camber kit already?? do u think there will be any issues with running just the front camber kit only?? by the way, what grease are u gonna use?? i was thinking using some top grade marine grease for the castor rods.
yeah.. apparently any form of aftermarket replacement of the arms is classified any illegal :rofl:
i have got whiteline camber kit for the front and rear of my car. Had to get an extra sets for the rears in order to correct my camber (was sitting at 2.8 degrees :rofl:)
as for the KTS rods, John (UAS) recommend NOT using any form of lubricant or grease. He made a post about it in the group buy thread so i just going to leave it raw :rofl:
"For those installing themselves use never seize grease or some sort of lubricant or grease on the thread as they are dissimilar metals and can become locked from corrosion." quoted from john.
is this what your talking about? do u mean to leaving it raw as in where the ball is? from what i can make of it he reccomends to use grease on the thread and nuts. doesnt say anything about the ball joint so i guess u dont need to lubricate that then??
...do u mean to leaving it raw as in where the ball is?..
haha... that sounded abit wrong :rofl:
but yeah.. a mate of mine just installed his cusco casters and the joints are similar to the KTS ones... i will check with him and let you know again. Another person to ask will be our SAU guru - SK :love:
Well if you wanted to replace bushes that get worn then you'd do the upper control arm bushes and the lower control arm bushes as well. (apart from caster). Whiteline sell the bits needed and if you look around on their site Skylines (apart from the 34) are supported rather well.
You might as well get a new front Whiteline adj. swaybar while you're at it :D
Hi guys, decent spherical bearings come with grease nipples (or provision for nipples to be screwed in). This is so you can lubricate them from the inside out. This achieves 2 things, firstly it obviously lubricates the joint. But more importantly, it pushes out any contaminents (dust, dirt, worn bearing metal etc) from inside the bearing itself. Think of how a main bearing works in an engine, it is lubricated from the inside out for exactly the same reasons.
Decent sphericals also come with covers and/or seals that stop the dirt, dust etc from getting in there in the first place.
Personally I would NEVER buy sphericals that don't have grease nipples and dust covers/seals and that's for a race car. I don't believe in using sphericals on road cars, they knock something fierce and wear out very quickly
Hope that helps:cheers:
bugger me!! now im worried as to how long these will last cause they didnt come with any dust boots or grease nipples. i might just have to wrap em in plastic:D maybe i should have gone for those adj bushes instead...hmmm.
by the way, how much castor can u have?? i just got mine installed yesterday and i have the urge to dial some more.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
