also i want one of those apillar (i think thats the a pillar) guage holders... anyone know where i can buy one online? cheapest ive found so far is 120
You sure about that cereal_jacques?
Autospeed had a gauge test a while ago and autometer did not fair too well.
I dunno, i'm changing to an apexi gauge because im not 100% on the accuracy. If i'm 0.01psi over 12 im going to start pinging even though i cant hear it, so i need accuracy.
uas (www.nismo.com.au) or jms (www.japanesemotorsport.com.au) have some... approx 70 bux for dble.
dunno if its a good idea if you want to get those pillar thingies tho... coz i used to have one (a double) to fit my oil press and boost gauge and it made a bit of a blind spot. not so bad but still annoying. and of course the probs with cops. ended up getting rid of it.
check out my pic. all i did was just buy the cup and bracket set (mines a 2" gauge) and used the existing screw to put it into place. crappy pic... will take better ones in the morn.
nice and stealth... well almost... and not easily seen from the outside.
cool... i want it somewhere where i can see it quickly at a glance so if im caning it i can see it without taking my eye off the rd too much... doesnt the steering wheel get in the way?
steering wheel *just* out of range. depends on where you put your hands tho. if your left hand holds your wheel at the 9 o'clock pos then yes. but if your left hand is on the gear knob, your right hand on the 12 o'clock pos and your leaning towards the middle then you will see it no probs! :D
mine's only an oil press gauge tho, so i only glance at it now and then...
lol
Yeah.....
Autometer are used for all the US drag cars.
It's obviously not gonna be as accurate as an electronic boost gauge, but it's a hell of alot better than splitfire or one of the other cheaper brands.....
A distributer once told me that Splitfire and Autometer are made at the same factory. Makes sense considering how similar Splitfire guages look to the ultralite series. In any case, I wouldn't trust any automotive guage to set boost pressure. Most of these are for interior decorating, not as a precision measuring tool. If you care for your ride, take it to a dyno and let them set boost level.
I've been through this my self when trying to set boost pressure. Guage read 12psi but I was getting a boost cut, and that only occurs at 14psi+.
I've got 2 VDO 52mm gauges in my A pillar mount and theres almost zero blind spot caused by it. I know the 60mm gauges do cause a bit of a blind spot. Theres only 8mm difference, but to look at them in a A pillar holder the difference looks massive.
The one I have, both gauges are behind the line of the steering wheel (if you know what I mean).....
I too went with VDO, they are standard equipment for a lot of Eurpoean cars and have good backup service.
I had to send my oil temp gauge back because the capilory was a little too short, they exchanged it without a question.
I can take some picies if you want to see them :)
J
dinesh: i dont think thats a good idea. boost pressure set on the dyno can differ from the road. for example my car was set at 14psi, get it out on the road and its nudging 1.1 bar (15.9psi)
i personally think a good guage is the best way to go. it tests the car under road conditions. the same conditions it is exposed to every day
thats ok im going to get it dynoed anyways as im doing a case by case report for all my mods which im puting on my page... with all the dyno sheets and basically a bang for buck type report
Was it set at 14psi using the dyno operators guage? Cause that kinda examplifies the inaccuracies in gauges I was talking about.
But otherwise, yeah, boost levels change under different loads or in different gears. Its the trade off we pay for using pneumatic control. Personally, I'm not too worried about a psi or 2 of creep in higher gears. By that time, the car would be pushing enough air thtough the cooler to cool down any extra heat from the turbo.
The fact remains, most guages are should be considered inaccurate until proved otherwise by testing. Still, they are useful for monitoring extremes changes in pressure.
I dont care what anyone says and that is pillar gauges do stuff with your vision and it is a pain in the arse..
once you get used to it if you move your head around them you can see everything..
So i have adjusted to them.. sometimes i hit my hand on them when palming the steering wheel
Another reason why the police book you for them is because in a accident you can hit them with your head (OUCH) But sir i have a AIR BAG :)
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
    • I like this page, better than that silly turbo kit   https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/
    • That would be my Shoei helmet
