having this hot weather comming on and my leather seats burning my a$$ i thought it would be to get my shitty air con working
now theres gotta be other r32's with the same problem out there
basically the air con only blows out air at the outside temp.
the heater works fine though.
is there a part that i can replace that will fix it?? or does it need re-gasing?
if so isnt there an old type of gas and a new type, and the old type would have to be totally replaced?
please help me im losing 5kg everytime i drive
thanks
john
https://www.sau.com.au/forums/topic/57314-air-con-dramas/
Check to make sure the air con belt is still on, and if it is, and it's still only blowing outside air, then it most definately from the sounds of it, needs regassing, there are two types of gas, not sure what the r32 uses, and not sure of the particulars, my r33's aircon has always worked fine so never needed to check up on it, but i needed to regas the excel, and that cost me 158 bucks! ... hope some of this helps.
https://www.sau.com.au/forums/topic/57314-air-con-dramas/#findComment-1106409
Compressor could also be stuffed. I've got to get mine looked at as well
If you find somewhere good for the regas who doesn't rape your arse pirce wise, post it up as I'm sure there would be a few of us in this same boat.
https://www.sau.com.au/forums/topic/57314-air-con-dramas/#findComment-1106810
silver gts-t, its unusual that the clutch on your compressor will engage if you have no gas in the system as there is a pressure switch to combat this. Ask yourself, if you have no gas how did it escape? Usually its due to an o ring failure. If the system hasn't had gas for sometime then the problem is multiplied as a lubricant is added with the gas to keep the o rings moist etc. Plenty of places will be happy to gas the system for you but ensure they use a "squeeler" afterwards to detect if any gas is escaping under load, otherwise you'll be visiting them quite regularly for the $150 privilege.
https://www.sau.com.au/forums/topic/57314-air-con-dramas/#findComment-1107223
    • Kaizo Industries put a VIN plate over where the Nissan plate would go. It was part of how they broke the law and attracted feds going after them.
