Greg,
Chris is correct,Warren with the white gtr put some on the second to softest compound and he said he cannot believe the difference it makes.Thats on a gtr so one can only imagine what it would be like on a high horse power gts-t.
Regards,
SKYLINE (Kym)....
https://www.sau.com.au/forums/topic/57336-tyre-outlets/#findComment-1107505
Blackwood Tyrepower is the distrubutor for TOYO's.
They have the cheapest RA1's available as obviously every one has to go through them.
How do the RA1's pull up against the RE55S?
From what I can see the RE55S have more of a semislick aggressive look.
https://www.sau.com.au/forums/topic/57336-tyre-outlets/#findComment-1111222
The S in RE55S means seriously sticky like sh@t on a blanket. they reduce inherent understeer in the GTR and give better turn in. However the biggest improvement is with the reduction in power on oversteer also inherent bigtime in a GTR. I guess all those with a drift bent would see this as a handicap but those of us who like to chew on everything that goes around corners including motorbikes in the hills there is nothing like them. I bought the WT compound SOFT. There is a SUPER SOFT MEDIUM and HARD. I looked at all the other DOT rated slicks DUNLOP TOYO MICHELIN PIRELLI etc. The Bridgestone is almost half the price of all. This means you can wear out two sets for the price of one. Wish I had of known about the trackday I would have liked to worn them out
DOWNSIDE TO OWNING SEMISLICKS
1. ROAD NOISE
2. MOST OF THE TYRES ENDS UP ON THE CAR
3. NOT GOOD IN THE RAIN
https://www.sau.com.au/forums/topic/57336-tyre-outlets/#findComment-1111793
In my 15 minute drive to work in the rain this morning my front torgue guage
was wrapped around the endstock and that was just getting out of the driveway.
A couple of weeks of accumulated oil and road grime wasnt helping either. Much more fun and 10 minutes quicker on the way home. One other word about the tyres there is definately less tramlining than with the Falkens I had on before.
https://www.sau.com.au/forums/topic/57336-tyre-outlets/#findComment-1113127
Where did you buy yours (tyres) from? How much? I do a lot of driving in the hills, and wish to get rid of the understeer problem you mentioned.. I am currently looking at a set of yokies, but if the RE55s are cheap, then I got more money to spend on my engine!!!
https://www.sau.com.au/forums/topic/57336-tyre-outlets/#findComment-1113964
I had the old RE540s on the R33. They were great in the hills if the roads were smooth, but when they get bumpy & the rest of the time on the street they were such a pain I have got rid of them (of course, they had no tread left anyway!)
I have gone back to normal street yokos. Wont be quite as good for handling, but will make the car much more comfortable to drive.
I used to use Bridgestone in the city when Laurie was there. My last couple of sets came from Mag Wheel centre on Prospect Rd.
https://www.sau.com.au/forums/topic/57336-tyre-outlets/#findComment-1114678
Sorry for the late reply, been away. I bought them from Bridgestone in Magill Road. They are the only Bridgestone Motorsport Tyre Outlet. Cost was $365.00 each fitted, did notice however they were having a 4 for the price of 3 offer in the EASTERN STATES when I was in Sydney during the week dont know if the same here ask. Even more to spend on your car. BTW cost doesnt change for different compounds in the RE55. I would like to go to a lightweight 18x9 rim, the RE55 comes in a 265/35/18 which wouild increase the overall diameter of the wheel/tyre by 7.6mm just enough to fill the guards a bit more and prevent gutter rash along with 10mm more gripping than the 255/40/17 I m running. The price goes up to $415.00 each.
https://www.sau.com.au/forums/topic/57336-tyre-outlets/#findComment-1118998
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
