Hmmm.... well the RE5040's on the front and RE55S on the back seems to be a good mix atm, weren't too bad in the wet/damp in the hills tonight, the 104km/h dinger is freiking annoying and the car definitely still has the speed limiter, though it seems to be off the clock when it hits it, was somewhere near 6000 in 4th?  Not sure, wasn't really paying much attention to the dials
Yeah thats bout where the 180 limiter is Adam, round the 6000rpm mark in 4th gear...100km/h dinger?? I don't have that option THANK****!
  • 3 weeks later...
Anyone using 4piston calipers and have rims that fit? Its a nightmare of mine.I had to fit longer studs,fit spacers and then i can only use a 6.5" rim with a 205 tyre on the front to keep the tyre off the strut.sad me.
A bit late I know, but I presently have 16 x 7's +38 Mirage 5 spokes up front and they will fit fine with a 1 inch spacer to clear the 4 spot caliper.
Best spacer is bolt onto the hub, and has it's own standard studs to mount to, they are also the only type CAMS will approve for hillclimbs & supersprints.
I also have a set of BSS Lorinser rims (ex Mercedes) modified to 4 stud and they are 3 piece rims and I am getting new inner rims made up to widen them in an inch, so that I will then have 16 x 8's all round.
Cheers,
Dennis
    • R31 boot how I received the sub, cleaned and today new carpet installed. Thank you Solder!!!!
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
