Hey I've just installed a new intercooler myself and have a bit of a problem. The question is this: on the stock pipe that goes from the inlet plenum to the stock intercooler there is a small 'barb' on the side that the factory boost controller is attached to (I think). But the new intercooler I have just put in doesn't have this attachment on the pipe, and I had an aftermarket mechanical boost controller attached to this 'barb' on the stock pipe before the install. I was thinking of joining a similar nozzle to the new pipe, is this safe or will it blow up? Any suggestions?
"My eyes, the goggles, they do nothing!"
https://www.sau.com.au/forums/topic/57416-boost-controller/
Hey Dude,
Just drill a 1/4" hole in the new inlet pipe & weld ( or silver solder) a small piece of 1/4" pipe in there....easy :D & best
You can "T" into the carbon canister manifold line ( runs right above the turbo from the back of the plenum to the canister at the front passenger side ) OK
Just don't run a "T" from the fuel pressure reg. manifold line ( front of plenum ) cause as you bleed off pres. with your controller you'll be dropping the presure the reg see's too! Bad :P
https://www.sau.com.au/forums/topic/57416-boost-controller/#findComment-1107927
Well the kit came with Japanese instructions and it looks like they are suggesting to 'T' into the carbon canister manifold line like rep003 suggested. The line they are suggesting I tap into is a small line at the front of the plenum on the left hand side. Didn't wanna try to see what happens when I leave it off; the instructions of the boost controller lead me to believe the boost will soar to dangerous levels if I left the boost controller unplugged. If I'm using the line they are suggesting, it can't be bad right?
https://www.sau.com.au/forums/topic/57416-boost-controller/#findComment-1109117
After driving round a bit, noticed that the car starts OK but after a while it idles rough and sort of 'chugs' a little. While taking off it chugs a little too, but when I go over about 60 it seems to be fine. Does this sound like a boost issue? Keeping in mind I changed my timing belt before I installed the intercooler. Car doesn't stall or seem difficult to drive, no whining sounds from loose belt either. Maybe I'll just weld a pipe onto the inlet pipe and make things easier.
"Wow, this is the best game ever and I have only entered my name! THRILLHOUSE!"
https://www.sau.com.au/forums/topic/57416-boost-controller/#findComment-1110493
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
