Something seems to have happened to the contents of my original post, so here goes again...
I am after an R32 dash board, in as good condition as possible: no cracks, warps, air bubbles, etc. The dash on my car seems to have suffered from the couple of months of storage in Japan :P
Preferably in Sydney, but depending of shipping costs, its not essential.
Edit: Just to be clear, I am after a dash board, not the dash display :D
Lucien.
https://www.sau.com.au/forums/topic/57420-dash-for-r32/
I have one in melbourne, but it doesn't have the vents
All my vents are in tact, but a little warped from the pressure of the dash as it warped.
What condition is it in? Do you have some pics?
Cheers,
Lucien.
https://www.sau.com.au/forums/topic/57420-dash-for-r32/#findComment-1107764
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
