Ok, I have a Cefiro, 10inch JL sub, 5 1/4inch MB Quart Discus splits up the front, both running off amps.
Question being, do I need rear fill at all, I have some cheap VDO 4inch two ways I can put back there, or I can put the 6x9s back (the carrozza jap ones that sit on the parcel shelf). Like is putting anything back there going to distort the sound I already have, or will it just make it sound more 'full' so to speek.
Also, where would the best position for the sub be? (pre fab box)
https://www.sau.com.au/forums/topic/57430-rear-fill-needed/
Personal preference I reckon Dave...
I like a bit of rear fill, keeps the kids happy :P My setup basically: 12" Sub, 6.5" Splits in the doors. Both powered by the amp, 6.5" Coaxials in the parcel shelf powered by the deck with the fader slightly to the front...
I reckon the 6 x 9's would make a mess of the sound, but ultimately be louder... In your situation, I'd either go with the 4's or fork out for some cheapish 6.5 coax's...
https://www.sau.com.au/forums/topic/57430-rear-fill-needed/#findComment-1107869
Struttos on the money here - the 6x9's won't be great so the 4's or coaxs would be the go.
Personal preference - I have always liked rear fill but usually it only accounts for about 10-20% of what I hear in the front.
When there's someone in the back I up it a little so they don't just get bass'ed out (don't have sub in cefiro at the moment so no worries there).
At the moment my setup consists of a 4x60wrms (or so) pioneer gmx-414 amp powering 2 focal kvp2 6.5" splits up front.
The stock 6x9's are crap but are currently powered by the 7450 pioneer head unit for tiny amount of rear fill.
When I get off my fat ass I'll be ripping the stockies out and putting in some el-cheapo 6.5" phillips drivers in the back which came from a splits set but won't have the tweeters (one was crushed in the a piller so bugger it) and they will be running from the amp.
Can't afford my amp+sub yet but I'd like it to be a 1.400 audison + ID max 12" of some sort..... heh still don't have 1-1.5k for amp+sub so I think this may be in a year or two :rofl:
Good luck tho davo - nice avatar btw.
https://www.sau.com.au/forums/topic/57430-rear-fill-needed/#findComment-1108137
Again, 6x9's would be a poor choice as I find the tweeters to be too bright and will drag your sound stage to the rear.
6.5" coax's would be ideal and I usually fade the head unit around 75% to the amplified front, 25% rear.
https://www.sau.com.au/forums/topic/57430-rear-fill-needed/#findComment-1108390
When you put it that way I dont think I'll bother with the stuffing about.
Any thoughts on the sub positioning tho?
https://www.sau.com.au/forums/topic/57430-rear-fill-needed/#findComment-1109120
I have Rockford in front and in trunk. But I have also rear fill with Rockford coaxial, not just because there is space for it, but it is needed with the upcoming surround processor! :rant:
Regards
Håkan
https://www.sau.com.au/forums/topic/57430-rear-fill-needed/#findComment-1109268
']I have Rockford in front and in trunk. But I have also rear fill with Rockford coaxial, not just because there is space for it, but it is needed with the upcoming surround processor! :D
Regards
Håkan
That's because you're a crazy Euro with crazy gear in your car!! :wassup:
https://www.sau.com.au/forums/topic/57430-rear-fill-needed/#findComment-1109837
I don't understand the use of an American full range speaker when many of the local products are very good in Europe.
As for sub positioning, I would just put it where it is most practical for daily use of the car. As for firing direction, trial and error would be the best bet but not many can be bothered knocking up a dummy box for testing, unless of course you dont plan to mould the box shape into your install, then you could use the dummy box full time :D
https://www.sau.com.au/forums/topic/57430-rear-fill-needed/#findComment-1109923
yeah.... rear fill I think is essential actually for a good sounding setup. Some say its optional, but I disagree.
At the moment, in the R31 I just have a pair of 6" fronts, and a decent amp powered sub, but the whole setup still really lacks the "fullness" that I like where the sound is coming from all around you. It was much better in the R33, with the 4x speakers and the sub.
Don't use the 6x9's like people are saying, but some 6" (even cheaper ones) should do the job nicely.
https://www.sau.com.au/forums/topic/57430-rear-fill-needed/#findComment-1110740
Yop, and more is to come in that Skyline, I can promise you.
Btw, rear fill was included in the first step, no discussion when we did that. If there is a space for speakers, fill it! :D
Regards
Håkan
https://www.sau.com.au/forums/topic/57430-rear-fill-needed/#findComment-1111970
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
