Hey guys,
I recently purchased this turbo and was planning to use it on my ca18 silvia. I now have to sell my car so this turbo is up for sale. Its a rb25 turbo from a R33 which has been hiflowed and rebuilt by Precision Turbochargers in Port Macquarie. Its also been machined and now uses a larger sierra wheel. This turbo has been barely used and is like new. Would be a great upgrade for rb20 or even rb25
I can do $850 posted for quick sale, as funds are low atm :P
I am on the Sunshine Coast if you can pickup
https://www.sau.com.au/forums/topic/57441-rebuilthiflowed-r33-rb25-turbo/
I belive only the series 2 R33 turbo's are BB.......Going by the information i was able to obtain in regards to markings on the housings.......yours appears to be series 1.
I could be wrong of course (been known to happen :rofl: )
sorry to possibly hinder your sale......just feel it is better to be sure before sale rather than have the buyer come back after purchase upset. Good luck.......hope it is BB (that means mine is too then :rofl: )
I could be wrong of course (been known to happen :rolleyes: )
sorry to possibly hinder your sale......just feel it is better to be sure before sale rather than have the buyer come back after purchase upset.  Good luck.......hope it is BB (that means mine is too then :D )
Thanks RiverSide I was under the impression r33 turbos were BB. With the number on the cover can any one clear this up for me? if its either BB or not the rebuild/hiflow cost $1300 so this is a still a good price. Priced for a quick sale.
actually fane, I know for a fact that my R33 Series II turbo has 45v3 on it, not 45v2. If I were to hazard a guess, I would say it would be a rebuilt s1 turbo, which is still ball bearing anyway.
Good luck with sale!
Just throw a spanner in the works again.........what series would it be if it has V4 written on it?
Would that be off a very late model R33?
ps. I am being serious, I am looking at one for the wifes car it is stamped V4. With all those numbers flying around in this thread i thought you guys might have thought i was taking the piss.
stop dribbling shit
i had a vg30et turbo
which had 45v4
seen ones with 45v2
i dunno whats up with it but there all the same in some way
but yeah
series 2 rb20 and onwards turbos were ballbearing i heard
some vg30et turbos were aswell
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
    • Are you doing the work yourself or are you paying for labour?
