i reckon there's only one way to really find out man... take it to a wreckers and see what u can clip it into... even if you have to take the seatbelt out to do it....
or if it's cheap enough, replace it with a skyline or silvia belt and clip....
just thoughts...
https://www.sau.com.au/forums/topic/57464-seatbelts/#findComment-1108268
Oz-cefiro.........I have a drivers side buckle sitting here that i can't use.....where are you located?
If you wanna pay for postage you can have it :rant:  Can't be more than ten bucks anywhere in the country.......
I would be glad to pay for postage, does it include the bolt and strap? I live in adelaide, PM me with details.
Cheers guys for all your replies and the speed at which you did it.
Also if anyone has a spare or know anyone who has a eft-hand front indicator assembly i will buy it from you. Mine got smashed in transit :rant:
Cheers
David
https://www.sau.com.au/forums/topic/57464-seatbelts/#findComment-1109470
Also if anyone has a spare or know anyone who has a left-hand front indicator assembly i will buy it from you. Mine got smashed in transit and i'm having considerable difficulty in locating one :rant:
Cheers
David
https://www.sau.com.au/forums/topic/57464-seatbelts/#findComment-1109471
What do you mean by strap? It has the plastic stalk that attaches it to the seat......
I may need the bolt for my new belts though......not sure if the original bolts are used or new ones (never bothered to ask)
i'll be glad to take it off your hands, i'll PM you with my contact details to arrange something
Cheers
David
https://www.sau.com.au/forums/topic/57464-seatbelts/#findComment-1110012
