Hi everyone,
What are peoples thoughts on using shot peened standard rods or forged rods with forgged pistons if i want to run 1.5bar reliably?? I don’t really have the cash to go for the fogged rods, but I can afford to get my rods shot peened.
I will be getting the crank machined, engine blueprinted and and rebuilt with 87mm Arias Fogged pistons, shot peened rods, ARP rod bolts and new bearings along with sum baffles and new gaskets etc. I have Group A turbos, intercooler and bigger injectors. Apparently before i got the car it had dynoed over 300kw at the wheels, so i would like to achieve this aith the new setup.
History:
I just bought a R32 GTR 2 weeks ago and on my first night out piston 4 had a piece of metal come from somewhere (ring/detonation???) and F$#^*$ked my head!! So i have owned it for 2 weeks and the car has been in the garage for most of the time. :_(
It had been rebuilt 13,000kms ago by Unique MS in Sydney and i was aware that there had been some damage to the cylinder that failed cylinder as the compression was down to 90psi.
Cheers,
Francisco
https://www.sau.com.au/forums/topic/57481-r32-gtr-rebuild/
Hi everyone,
Im running basically the same setup. Upgraded bearings, standard rods shot peened with ARP rod bolts, Arias forged pistons, metal head gasket, o-ringed, balanced and blue printed. Used to run 1.5 bar on HKS GT2530's with standard camshafts, and now 1.25bar with Tomei poncams. Has been running for 15,000kms with no hiccups whats so ever (well at least in relation to the engine build).
I was told with the standard rods, keep to the factory rev limit and you wont have a problem 350awkw and under. We had part of my engine apart a few weeks ago and everything still looks as new.
EDIT: I as wactually told more than 350kw for the shot peened rods at factory rev limit, but 350kw is ample for what I want from the car.
https://www.sau.com.au/forums/topic/57481-r32-gtr-rebuild/#findComment-1108488
History:
sounds like you bought doge GTR,do you mind i ask you how much you pay for the car?couse i just want to know,if you pay right price for GTR,you should get very good example GTR,they are very strong engine,
i think you should bring the car back to the guy who sold the car to you,
good luck mate,
https://www.sau.com.au/forums/topic/57481-r32-gtr-rebuild/#findComment-1109442
yeah i did get ripped a little, but apart from the engine the car is super clean and has nice mags & good suspension. I thought i was getting a good deal for a R32 93 Vspec with the Brembo's etc but with the rebuild it will work out to be a little over market value. Thats the risk you take i guess.
Thanks for the comments above - i really want h beams but i cant afford them with the whole build, so i think i will have to settle for shot peened.
I will be getting a light port & polish, but once again i can afford to get cams at the moment.
https://www.sau.com.au/forums/topic/57481-r32-gtr-rebuild/#findComment-1109561
Trust the above few posts - once you've got the power bug, it bites hard. Especially so in an R as it get the power to the ground so well.
A year or so down the track when you're strapping on those high mount(s) you'll always have the thoughts of those std rods in the back of your mind. While your at it, check to make sure that the crankshaft/oil pump setup is of the later type.
https://www.sau.com.au/forums/topic/57481-r32-gtr-rebuild/#findComment-1110199
do the rods and dont be p!ssed off about the buy, after the rebuild the engine will be bullet proof and the car will be proper market value for a 93 V SPEC!!! atleast this way you will know the capabilities of the engine, so consider the rods and the rebuild as cheap insurance for the engine/car and peace of mind.
dreamer
https://www.sau.com.au/forums/topic/57481-r32-gtr-rebuild/#findComment-1110418
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
