  • Replies 46
I was thinking the same thing silverslyder, might be a bit far to do in a day....
well i'll have a look around in the next few days and see if i can find somewhere.
We've already done the Bateman's Bay thing, Kangaroo Valley, and the cotter for a barbie, so I was thinking something different to those might be good this time. Although we've got a few ppl who weren't around then..so..we could do the same i guess...
the Gong's pretty far too isn't it? Somewhere that's an hour & a half drive or so would be good...
aargh I'm just rambling...keep the 24th free everyone...we will definately do SOMETHING... :(
https://www.sau.com.au/forums/topic/5750-get-together/page/2/#findComment-90808
hi brendan! :( great idea...but a bit short notice for you Sydney guys maybe?...it's next weekend we're doing this
hmmm dunno, i think i'd prefer to keep it a more local thing this time, and then maybe organise another big-ass Canb/Sydney cruise down the track (like the Kangaroo Valley one we had) when we can give everyone plenty of notice... :(
https://www.sau.com.au/forums/topic/5750-get-together/page/2/#findComment-91556
hmmm dunno, i think i'd prefer to keep it a more local thing this time, and then maybe organise another big-ass Canb/Sydney cruise down the track (like the Kangaroo Valley one we had) when we can give everyone plenty of notice... :P
Yeah prolly right - no worries.:(:P
https://www.sau.com.au/forums/topic/5750-get-together/page/2/#findComment-91569
errrr no ;)
sorry guys, i've been busy this past weekend, and went up to Sydney on Sunday to help organise the NSW part of this club....I really haven't had time to think of somewhere to go ;)
we could always do the coast run again? and maybe head up to Ulladulla for a late lunch?
https://www.sau.com.au/forums/topic/5750-get-together/page/2/#findComment-94219
lets do a wollongong cruise at 6 on sat mornin, oh and how convenient i have to pick up my turbo as well hahha. Sorry i wont be at the cruise i always seem to miss these things hey, but my car is in a 100 peices nah seriously i counted the pieces i i think there is like 112 pieces (pis.sed) Might try n bring the gtst if its not goin to be a long cruise
https://www.sau.com.au/forums/topic/5750-get-together/page/2/#findComment-95624
Originally posted by Jay95R33
I'll be driving by myself and I'll be getting real bored !!!
hehe me too Jay :P BF has ditched me and is working instead :D
yeah silverslyder, I agree lets just keep it local..we need much more planning to do a bigger longer cruise, cos u really need to work out times, distances, a proper route, lunch etc....and i just haven't had the time (although anyone else is always welcome to jump in! :) )
how about we just meet at 12pm Civic, and just do the cotter thing....we can go via Uriarra (longer, fun road), go straight past the pub, and maybe head up one of those roads that go to Corin or whatever, then at tharwa we could head to honeysuckle ck for a looksy...
ppl coming:
Shell
Jay
polishstorm
silverslyder
TomR33
whytry
AlexR31
R32_GTS4T (maybe)
s13drifter (maybe)
all u guys still intersted?
https://www.sau.com.au/forums/topic/5750-get-together/page/2/#findComment-95710
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
