Hey just wondering if any1 had heard of MB Quart speakers and whether or not they are any good? Just put a deposit on some DSE-216 6 1/2 splits without really thinking about it!!! I usually restrict myself to the more well know makes and have kinda stepped out of the circle on this one! Any feedback will b much appreciated!!! Happy lining!! (i mean SKY-lining!!!)
https://www.sau.com.au/forums/topic/57504-mb-quart/
Did you listen to them?
If you liked em then you should be happy regardless.
A few years ago they really were a real presence on the market but they seemed to be overwhelmed once the focal hype hit the streets. They are a good speaker though, I am not familiar with the models anymore.
https://www.sau.com.au/forums/topic/57504-mb-quart/#findComment-1109031
I go the 5 1/4 inch discus series in my car, and MY GOD! I love them hey, I want to hug them every nite almost, they are so damn clear!
I really need the 6 1/2s for the music I listen to, so enjoy them. (ps, wanta swap for the smaller speaker :rant: )
https://www.sau.com.au/forums/topic/57504-mb-quart/#findComment-1109109
hahaha yeah i'll swap em for a frount mount!!!! sweet...i'm stoked that someone is happy with em!!! got the 6 1/2 components for 329 from a place called stylin audio in melbourne.....went there to buy an immobiliser and thats all....i took only money for the immobiliser coz i knew if i took my cards i would end up buying stuff that i can't really afford!!! immobilizer ended up being 50 bucks less than i thought so i put 50 deposit on the quarts.......always happens!!!
https://www.sau.com.au/forums/topic/57504-mb-quart/#findComment-1109124
What range are they? When I got mine they had the top of the line 6 1/2s for cost price ($500 or something) if I had the extra $300 I would have got them. Id say thats a good buy. (espcially when my mate got a quote for $700 for some alpine things). Just the one tip Id have. Mount the tweeters lower rather than higher, I find them a little harsh at times.
https://www.sau.com.au/forums/topic/57504-mb-quart/#findComment-1109138
Yeah I'm gonna get them to install em...pretty much can't be stuffed, and they installed my immobilizer.........oh yeah thats what i was writing........just had a massive blue with my ex over money she owes me anyway.........yeah they did a great job with the immobilizer so il get em to do the speakers too
range??? im not sure, i was going to get the tweets mounted on the a-piller but i actually also just read that thats probably not a good idea so awesome thanks for the advice il get em mounted down low....what r u running in the rear daveo?
https://www.sau.com.au/forums/topic/57504-mb-quart/#findComment-1109236
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
