Hi guys.. just registered :rant:. I have just purchased a R34 GT-T (Not my first skyline i had a non turbo r33 95 skyline) My question is in regards to the boost setting for the standard neo turbo just for street use. The mods on the vehicle atm are minor just cat back 3 inch exhaust, bov, and airpod. I need to know what boost is recommended and what boost not to exceed etc. I also want to put a front mount intercooler on and possibly get the turbo highflowed does anyone know of any good reliable shops in the brisbane area that can do these mods. Thx for your time guys.. no doubt ill have heaps more questions as i learn more about the RB25DET.
https://www.sau.com.au/forums/topic/57509-newby-help/
the compressor wheel is plastic or ceramic (unsure) and will get angry over probably 12psi. Try it at say 11psi and see how it goes. The stock ecu will have boost cut limits etc but it wont prevent ceramic compressor wheel failure due to heat from the excess boost. You should get good response from 12psi, pod filter, exhaust and intercooler easily 200rwkw i'd say
https://www.sau.com.au/forums/topic/57509-newby-help/#findComment-1109157
Thx for your help.. The turbo engine is a completely new world for me. Im not even familiar with the boost controller atm. Going from the non turbo 33 to the GT-T is awsome .. such a massive difference in power. Im aiming for a 250 rwkw after the highflow and intercooler. The last thing i want to do is blow something cause ive upd the boost to much. Thx again
https://www.sau.com.au/forums/topic/57509-newby-help/#findComment-1109266
Turbowns,
Firstly, congrats on an awesome step up, R34's rock!
Boost, many claim that all it can handle is about 12psi, I have been running 14odd for over a year no probs, however std boost on mine is about 11. Be careful because the turbo is ceramic/nylon. Make sure you get FMIC before playing with boost too much (and turbo back exhaust) or you will seriously risk f%&king your turbo.
Can't comment on hi-flowing turbo as I have heard conflicting stories.
As you mod the R34 more the first thing that will annoy you is boost/fuel cut, a safety measure to prevent overboosting/detonation. Regardless of mods the only way you will get the car above about 200rwkw's is by changing or piggybacking the ECU (ie Emanage/PowerFC etc). I believe to get to 250rwkw you will also need turbo back exhaust, FMIC, ECU mod, fuel pump and injectors if not more.
I have heard good things about 101 motorcafe, particularly for ECU work. Give them a call and they should be able to guide you through the whole process, alternatively on the GC try Autech (Gavin Wood) in labrador.
Cheers
https://www.sau.com.au/forums/topic/57509-newby-help/#findComment-1109629
Turbowns,
Cheers
Ok what is FMIC?
https://www.sau.com.au/forums/topic/57509-newby-help/#findComment-1109664
What year/month is your 34?? If it is a late 2001 (Series 2) onwards you may find that the turbo is metal/metal.
There is a detailed thread on this site about the differences between r33-r34. Here it lists a guide on how to find exact details of your car.
Hope this helps.
https://www.sau.com.au/forums/topic/57509-newby-help/#findComment-1110151
Hope this helps.
Its a 1998 model series 1
https://www.sau.com.au/forums/topic/57509-newby-help/#findComment-1110258
