thoughts on new sticker design (pics)
Ok, as some of you will know i have been given the task of making some SAU stickers for club members etc. i serched for (SAU LOGOS) on these forums and i came across a few ideas from other members.
I ask gary1, what he thought of the idea and we agreed i would make a few samples.
Today we got around to cutting the stickers , there are two diffrent styles. i have sent 8 of each style to gary1.
i just stuck one of each on my car and took some pics so i could get a feed back from YOU !!
Please let me know what you all think.
https://www.sau.com.au/forums/topic/57512-thoughts-on-new-sticker-design-pics/
That's some nice spamming for SAu Mr Sparkle :rant:
I'm with Mase on this one. I like the last one. The red and silver on the back panel. Can we maybe get just the url's done as well www.skylinesaustralia.com but with the SAU bit in the middle a different colour or something? Just a suggestiong. Just thinking of something like that to match the other ones.
The first two that Melv has posted if what's printed on the buckle of the lanyard that funkymonkey down south has made. Looks awesome on there. I just like the slimmer longer one. Rather than the tall skinny one?
... If that makes sense
I like those ones the way they are.. not too cluttered... and you can still read it.
like the "set" we've got now is the two side window ones and the long url one.. How does that one on the panel look if you squash it down to fit that rear glass bit?
i could do that
have a set. like two of those long ones and a www.skylinesaustralia.com or www.sau.com.au sticker on its own.
:type:
I like them all tops work dude!!! :(
Left you a voicemail on your mobile too bout the club stickers just to see where they are at (sorry for hijacking thread).
But yeah AWESOME!
EDIT: Hey can you make stickers which are see through from the inside? so you could make a massive one for the rear windscreen and stuff? Prolly cost a fortune though I'd imagine :) The ricer in me has to know :(
Wouldn't mind a mirror image one to go across top of the windscreen, and or straight one for top of the rear screen. Don't fancy putting big solid stickers on the rear quarter glass. Might cut down the rear peripheral vision too much. I liked the origional small one for that area. Like the big panel one though, maybe a dot com on the end....everyone knows to put the www in front.
If anyone feels creative I'm looking for designs to put on the white 2 door (semi sedan Strutto???)
    • The jack pad placement always had me scratching my head. I only have a small section to work with on both the E90 and E70 (and insert new project car here ) and I could see lining it up to be a bit of a bugger. For me, the E90 is just too low and needs small ramps and then the front centre jack point is a bit tricky to line up (it's half way down the subframe and about the size of a tennis ball, its really hard to see unless your head is on the ground), so I definitely like the idea of not having to do a multi-stage jack and just sliding these bad boys in under the sides. There's only one small point at each corner, so I can't jack AND add a stand on the same corner. Or, maybe I can and I'm too nervous to try. 😟
    • Is this not the biggest deal of all? I was hoping the whole "will slide under cars with skirts etc and lift evenly quickly with minimal fuss" was the entire point of such a device?
    • Here's Neil's car up on mine recently
    • Yeah I've got one of these, Quick Jack not Quick Lift, but your link looks like a good copy For me, it's better than no hoist, but it is definitely not as good as a hoist  It lifts the car about 60cm which is a nice working height compared to regular stands and it is only under the sills so it doesn't get in the way like regular chassis stands do.  No need to use regular stands, it has a safety lock on it. On the down side it is really heavy/unwieldy to drag into place, and you have to place it after the car is there (no option to drive the car to where the frames are. You need to try and line it up with the proper sill points which is hard as it swings up in an arc and there is surprisingly little adjustment in the distance between the rubber pads for different car lengths. Not a big deal, but in practice a jack + stands is probably quicker. Also there are hydraulic lines to each side and you need either a 240v or 12v source to power it depending on which option you have, I use 12v as I always seem to have a battery around.
    • Finally addressing my catch can and oil setup Plan is to do as much as practical without having to remove the motor or pull it apart. (no back of head to sump drain/breather or oil restrictors) First step is a set of full length baffle plates from Hypertune and a Tomei cam cap stud kit. I could probably have laser cut and bent up my own ones but this took any guess work out
